Author Topic: Clutch plate/disk placement on cb 500?  (Read 562 times)
Offline Moosey
« on: March 29, 2015, 04:30:22 PM »
I have replacing the disks and plates on my cb500 and have seen somewhere on this forum that there is a specific orientation in the way the disks face. Ive searched but could not find answer. Anyone can chime in?
Offline Moosey
Re: Clutch plate/disk placement on cb 500?
« Reply #1 on: March 29, 2015, 07:50:47 PM »
bump
Offline Bootsey
« Reply #2 on: March 29, 2015, 09:05:59 PM »
Are you referring to the steel plates or the friction plates? I think the steel plates generally have one side with a chamfered inner edge, and one flat edge - as far as I've been able to find, the square edge should be the motor side, and the chamfered edge, the outside. Make sure the steel plates are all orientated the same way.
Do the friction plates grooves have slanted or square cut faces? If they have square cut, won't matter which way they are stacked, if they are angled, stack them so that they throw oil outwards as they spin.
Here's a couple of links
http://forums.sohc4.net/index.php/topic,141122.msg1599650.html#msg1599650
http://forums.sohc4.net/index.php/topic,68423.msg1356382.html#msg1356382
http://forums.sohc4.net/index.php/topic,90832.msg1016408.html#msg1016408
« Last Edit: March 29, 2015, 09:12:13 PM by Bootsey »
Offline Moosey
« Reply #3 on: March 29, 2015, 09:12:14 PM »
Thats the answer i was looking for. Thanks so much.
