Author Topic: Cam chain tensioner o-ring  (Read 950 times)
Offline tfrasca
    • CB550 Project
« on: March 29, 2015, 08:38:29 PM »
Is there any way to replace the cam chain tensioner o-ring from outside the motor on a '76 CB550K? From the parts fiche, it looks like there's a ring around the stud from the inside, and it doesn't look like you can get to it from outside the motor. Mine's leaking like a sieve and I'd love to easily replace it...
Thanks,
TF
Offline eigenvector
Re: Cam chain tensioner o-ring
« Reply #1 on: March 29, 2015, 09:12:08 PM »
I'm not sure it matters whether the ring is on the outside or the inside, so long as the gap is plugged.  Mine was installed on the outside.  After tightening the tensioner the o-ring is wedged into the gap, sealing it.
Optimally it should be on the inside though.
Why not just put an o-ring on from the outside and see how it works?   They're cheap enough.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline mrfish2
  • I might be a
« Reply #2 on: March 29, 2015, 10:54:00 PM »
I did this on mine. The washer behind the nut presses the o-ring into place. I haven't had any leaks from that area so far.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #3 on: March 30, 2015, 05:28:32 AM »
It installs from the outside into a recess for it. Don't damage the aluminum removing the old one and grease the new one well. The threads on the tensioner make it a little difficult getting it in place without potential damage to the oring.
Offline tfrasca
    • CB550 Project
« Reply #4 on: March 30, 2015, 07:37:13 AM »
Well that's embarrassing. I removed the nut on the tensioner a while back looking for an oring to replace, but didn't find one and  I guess I didn't notice a recess in outside of the cylinder. But it's good to hear I was wrong. Thanks guys.
