Author Topic: cold start issues cb750k6 / 4  (Read 383 times)
Offline hereford
« on: March 30, 2015, 07:23:39 PM »
hey got another 76 k series but with a 74 motor in it but motor wont start easy. wind over for long time then when it does start blows heap of
white-ish smoke but once warmed up starts first touch of starter motor and no smoke. initially thought valve stem seals , oily spark plugs but then checked compression, cold motor crank over 3 or 4 revs and compression tester shows about 90 psi on all cylinders. any suggestions
