Author Topic: CB350F Cylinder Sud Removal  (Read 1021 times)
Offline lhemrick
« on: March 30, 2015, 05:05:28 PM »
Is it possible to remove a cylinder stud from an engine after just removing the valve cover? The reason I ask is I have some oil weaping out from where the stud passes through the lower base of the cylinder bank into the lower crank case. I built the engine about four years ago would rather not take the engine apart again without trying any other simple fix first of course. Any one have any suggestions?
Don't give up; Rust is only Temporary!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
Re: CB350F Cylinder Sud Removal
« Reply #1 on: March 30, 2015, 05:19:24 PM »
Use heat and penetrating liquid of some kind.  I would recommend using a stud puller as well to lessen the chance of snaping a stud off.  APE makes one.
http://racetoolz.com/
Offline calj737
  • I refuse...
« Reply #2 on: March 30, 2015, 05:45:22 PM »
It may be possible to do what you ask, but it's certainly not a good idea... The likelihood of snapping the stud is pretty high and that will create a lot more work. There's no way to apply heat to the stud at the block with the head still on the motor.
Offline lhemrick
« Reply #3 on: March 30, 2015, 06:05:33 PM »
I just replaced a valve cover gasket because of a leak. Now I find this one. How is the oil getting out of there? It's after you get the engine hot and coming off throttle to idle it bubbles up around the stud.
« Last Edit: March 30, 2015, 07:18:20 PM by lhemrick »
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
Offline lhemrick
« Reply #4 on: March 31, 2015, 04:15:29 PM »
Found the simple fix! Pulled the Valve Cover back off and retorqued the cylinder and stopped the leak!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
« Reply #5 on: March 31, 2015, 05:02:08 PM »
Excellent. I guess we assumed that had already been explored.
Offline lhemrick
« Reply #6 on: April 01, 2015, 03:04:28 AM »
That would have made sense but I was on my 24 hr shift looking for info or possible solutions for the next day. Got home and dove in and tried the torque solution. Never dreamed it would actually work! Thanks for the input!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
