Author Topic: Fuel line that withstand gasoline, ethanol, other chemicals  (Read 2552 times)
« on: March 31, 2015, 12:37:07 PM »
I have had some issues with cheap fuel hose from cheap autostore. Hose that collapsed after a few hours of use and blocked fuel line.
I had to fix that before tuning my carbs when lack of fuel tricked me to have jetted too lean....
- Any favourite brands of hose that work well? I ask here when the racers must have more experience of tough chemicals feeding the engines
I got 2 models of hose today, both from Gates, made in USA that must be better than China hose. Gates Universal 3225 (ID 8mm) and probably the better "Gates BarricadeĀ® 4219BF Fuel Injection Hose" (ID 7.9mm) that take bio-fuel too.
http://www.gates.com/products/automotive/passenger-car-and-light-truck/fuel-system/barricade-fuel-injection-hose-mpi
Both hoses in 6mm model too. It will be plumming from tank. Begin with short 2x6mm hose - 90 degrees plastic corners, hoses entering the carbs from above. 6mm to 8mm hose to carbs with plastic corners. I must have a consistent flow of fuel via lines that will not fall off or collaps.
« Last Edit: March 31, 2015, 12:50:08 PM by PeWe »
Offline Bob Wessner
  • "Carbs Suck!"
Re: Fuel line that withstand gasoline, ethanol, other chemicals
« Reply #1 on: March 31, 2015, 12:42:12 PM »
Can't recommend a brand, but look for "nitrile" fuel hose.
« Reply #2 on: March 31, 2015, 01:09:00 PM »
One of the Gates are specified as nitrile hose, 3225 model.
The other that cost more is more exotic. HNBR tube with thermoplastic barrier, aramid fiber reinforcement, CPE cover
I guess the hose I got will due. I'll update the fuel line plumming later.
Offline Old Scrambler
« Reply #3 on: April 01, 2015, 07:06:31 AM »
I much prefer BRASS corners over plastic or nylon.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #4 on: April 01, 2015, 11:31:13 AM »
Yes, I should purchase brass before plastic too. But I have only found plastic versions in these small dimensions, 6 and 8mm ID hoses.
I did the fuel line plumming this afternoon direct after work with the "Gates Barricade 4219BF" hose. It is tighter and seal better whith 7.9mm ID and stiffer.
Carb 1-2 connection got a 6mm hose from tank routed with natural bend to the front of carb 1-2. Here cut hose and connect with 7.9mm hose via 90* corner with reduction. Then another 'natural' bend to the carb T-pipe. It fits well and needed to press hose over the t-pipe. Hose clamp for keep hose in place, not for sealing.
Carb 3-4 needed advanced plumming :D Short 6mm hose from tank, 90* corner direct with 6mm on other side all the way thur the carb rack over the T-pipe on carb 3-4. Here cut 6mm hose and connect to 7.9 mm hose via 90* corner with reducer, 6mm -7.9mm. Last hose 7,9mm ID and about 6-7cm cm long, (2.5").
The fuel seems to be good routed without kinks or flow blocked by impossible bends, height difference with air bubbles.
« Reply #5 on: April 01, 2015, 12:04:24 PM »
Sanitary install..............may want to take it easy on reserve and find the closest fuel-station.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #6 on: April 01, 2015, 12:43:35 PM »
I'm not clear about how the old style petcock work. I'm used to the K6 petcock with single fuel pipe. Y-connection to OEM carbs.
The old style petcock has dual pipes out and I'm not sure if both will have same flow @ std position or reserve.
- Do I need to connect the 2 outlets to one via Y-connection - hose and Y-connection again to 2 hoses? This will ensure same flow to both hoses feeding carbs, normal or reserve. But all connections might reduce total flow.
I have read an old thread about the petcock, but I'm not sure...  http://forums.sohc4.net/index.php?topic=11549.0
Offline dusterdude
« Reply #7 on: April 01, 2015, 03:39:58 PM »
You will need to y or tee it on a single hose carb application
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #8 on: April 02, 2015, 03:14:08 AM »
OK, my carbs have 2 fuel inlets. I can check my petcock (in reserve pos) with a few liter  in the tank and see if it flows from both pipes. I guess there is a risk that they can flow different.
I had single hose carbs last year, Mikuni VM29. I blocked one of the pipes from petcock, a hose with screw + clamp. This scratched my frame every time I lifted the tank. Many lifts....
« Reply #9 on: April 02, 2015, 07:02:12 AM »
With one of your lines going up-and-over the carbs, the minimal head pressure from the tank when on reserve will tend to reduce the flow. The 2-spigot petcock was used by Honda from '62 through '75. I have rebuilt a dozen or more for the CL72 and CL77 models. One of the spigots will tend to drip rather than 'stream' when on reserve. On the twin-carb motors, one spigot fed each carb.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #10 on: April 02, 2015, 02:12:55 PM »
I guessed that the last liter or 2 in tank can cause bad flow from the petcock.
- Rebuild for better flow? Shorten the brass pipe on petcock inside tank so reserve will come later, flow from both...?
I have another tank, new with same kind of old style petcock. Plus another good tank with new old style petcock....
« Reply #11 on: April 02, 2015, 06:37:44 PM »
They get the job done when clean.  The petcock on my K3 works great and actually shuts the fuel off.............and its totally original, never been apart. :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #12 on: April 03, 2015, 02:46:34 PM »
OK, my petcock is clean and look almost as good as my other new ones. I removed it and changed o-ring and bolts + new bowl that had a small hole leaking fuel.
« Last Edit: April 05, 2015, 03:08:35 PM by PeWe »
