Author Topic: 466 project turned in to a 3+ year gig. now redoing the transmission.  (Read 17120 times)
Offline Jore
Re: 400(466) project turned in to a 3+ year gig. About to split cases.
« Reply #125 on: December 08, 2015, 09:55:17 PM »
I managed to remove the rotor, a M18x1.5 bolt is what's used to remove it if anyone's wondering about the size. Tomorrow I'll have another go and hope I can split the cases during the weekend and maybe prep them for paint.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Offline straat-toe
  • Everybody knows about the bird.
« Reply #126 on: December 08, 2015, 10:37:18 PM »
Hey Jore.
Good to see you got enjoyment out of the bike before taking it apart. Unlike me. I'm finally rebuilding the engine a few years down the line.  If this is your first time splittng the 400 cases. Remember to take the Primary shaft out.
It makes splitting the cases much easier when the primary chain isn't attached to both the primary shaft and the crank shaft. The tensioner that's attached to the top case loops around the crank and holds the cases pretty much together while the primary chain is still on the primary shaft..... You might already be aware of it. Just thought I would give you a heads-up. This was my biggest Noob learning curve when I split my 400.
Good luck.
No School, No Job, No Worries.
Offline Jore
« Reply #127 on: December 09, 2015, 08:23:00 PM »
Thanks Straat, i think I managed to ride it for about 300 km before taking it apart, it's been about 2 years now since I've ridden it.
1975 CB400F owner
    • http://forums.sohc4.net/index.php?PHPSESSID=lbkenoq7io08soi78436jj1e40&/topic,60973.0.html
« Reply #128 on: December 10, 2015, 06:09:55 AM »
on mine first 400 f..i had big problems..to get the crankshaft ,and that horseshue tensioner..to free
..think i vill cut the cam chain..on my NeXT procjekt..think it vill free it up.
.hope to get on the 400.. this Winter..have only have one ride 150 km..on the bike..the rattel vas to hard..so put it avay for better times...riding the 550 ..last seson..
Offline Jore
« Reply #129 on: December 10, 2015, 09:46:16 PM »
I haven't played around much with the chain, but a few days back I could slide some parts around without to much trouble, hope it's the same deal with the chain.
Also being that I now have an electric impact wrench disassembly is going so much smoother I had been having trouble removing the front chain sprocket because it would spin on it's every time I tried using a spanner or socket on it, with the impact it was less than a minute!
1975 CB400F owner
Offline Jore
« Reply #130 on: December 10, 2015, 09:58:06 PM »
By the way after removing the sprocket I found this:
Besides being really grimey, it appears to have a wad of human hair  ??? no idea on how that got there, either way I'm cleaning that up and replacing the oil seal.
1975 CB400F owner
Offline Jore
Re: 400(466) project turned in to a 3+ year gig. Cases are split!
« Reply #131 on: December 12, 2015, 05:10:28 PM »
THE CASES ARE SPLIT!!!!!!!!!
I've split them today, surprisingly the most complicated part was removing a snap ring, the cheapo pliers I had bent, so I had to get new ones, everything else was pretty straight forward.
I first moved the housing to a work bench.
Then I drilled the bench so I could pass the stud through
And that was the setup
I marked a piece of cardboard to place all the bolts and split the cases, it was really easy (you can see the cardboard in the back there) I also found out that I could run my impact driver with the old battery.
The trans looks good and the shift forks are thick and don't seem to be worn out
It started to get dark so I just wrapped the trans in some cling film and called it a day.
I'll continue tomorrow.
1975 CB400F owner
Offline Jore
« Reply #132 on: December 18, 2015, 01:55:06 PM »
Today I changed the drain plug on the oil pan. The original one was pretty mangled up and almost round, the PO appears to only have worked on the bike using vice grips and a hammer.
This is the original one:
A side to side on both of them, the new one is stainless steel slightly thicker and has a magnet on it, I got it at a local parts store It's an M14 size.
I drilled the original threads since some of those where also messed up and tapped the new ones, from the inside clearance seems to be good also.
I also gave the oil pan a coat of bed lining, originally I had painted it silver like the  breather cover, but It didn't look the way I wanted so it ended up being black.
Later today I'll head down to the machine shop and figure out a solution to the cam adjuster, I'm leaning towards something like this:
1975 CB400F owner
Offline Redline it
  • thread killer
« Reply #133 on: December 18, 2015, 08:18:19 PM »
I wonder if the PO knew about using metric vice grips. Youtube's Ichiban Moto high tech cafe racer builder demonstrates the correct use of specialized tools, like metric vice grips.
« Reply #134 on: December 19, 2015, 03:33:32 AM »
uou need a o ring to make it leak free..that oil vill kreep through the threddet part..or give it some thik lockteit..
i have made one like yours..but it still rattel..so think my thain are gone to far..
have to make a better tensioner bolt. this one is a test. think it vill leak..need to make a cylendric part the o ring rest against,,and a groove it can seat in
« Last Edit: December 19, 2015, 04:11:19 AM by strynboen »
Offline Jore
« Reply #135 on: December 19, 2015, 10:05:47 AM »
Thanks for the o-ring idea, hadn't thought of that.
1975 CB400F owner
Offline Restoration Fan
  • My wife will never call me
« Reply #136 on: December 19, 2015, 10:16:50 AM »
LOL, I saw that episode.  The first couple of videos of his that I watched, I was like WTF?  Then I realized I was being stupid because he was just spoofing stuff.  At that point, I started enjoying his videos again...they're 'badass".  8)
Offline Jore
« Reply #137 on: December 19, 2015, 10:41:50 AM »
I'll have to start watching those then lol.
1975 CB400F owner
Offline thirsty 1
« Reply #138 on: December 20, 2015, 09:26:00 PM »
Put the lower locking nut in a vice. Use a 3/8" drill bit and drill a chamfer into the nut. Install a oring the size of the adjuster stud and Voila' ! Oring on your adjuster.
Offline thirsty 1
« Reply #139 on: December 20, 2015, 09:30:27 PM »
sorry I missed this up above. Take the nut off and do the chamfer (counter sink) the o-ring.
Offline Redline it
  • thread killer
« Reply #140 on: December 20, 2015, 10:10:25 PM »
What? Spoofing stuff? His tin snips are some bad ass cutters.
Offline Jore
« Reply #141 on: January 10, 2016, 01:35:17 PM »
Sorry for not updating anything but the holidays got in the way, I've got a new petcock for the tanks, it's a harley unit instead of something from honda, I'm using an adapter to mount it. Check out this post If you want further info:
http://forums.sohc4.net/index.php/topic,154341.msg1765195.html#msg1765195
And this is how the part looks:
1975 CB400F owner
Offline Jore
Re: 466 project turned in to a 3+ year gig. now redoing the transmission.
« Reply #142 on: January 20, 2016, 11:29:57 PM »
I got the cases painted and cured now, the turned out really well, now it's just a matter of putting the innards back in the correct order. So here are the pics of it.
Lower case, with oil filter adapter, also the oil pan and filter are painted truck bed lining.
Upper case
Lower case mounted in the frame to get an idea about fitting and clearance for the new filter. I got really exited when I saw this in place.
And finally the painted parts and the new seat
Now I need to get the innards back in to the cases, is there a more detailed manual on how to put that back? I have the service manual for the bike, but the instructions are kinda vague to my understanding. All the tips are welcome.
1975 CB400F owner
Offline Jore
« Reply #143 on: April 13, 2016, 08:33:34 PM »
Seems that most of my picture links are dead, I'll change those later on, In the mean time it's good to be back, I finally closed up the case and installed the transmission, now it's just a matter of setting up the linkage correctly so I can try going through the gears. What do you guys recommend when doing that, if the transmission works out correctly I'll install the top part and later on do a bench test run.
This is my progress so far:
1975 CB400F owner
Offline Jore
Re: 466 project turned in to a 3+ year gig. Engine in frame!
« Reply #144 on: June 05, 2016, 09:23:02 PM »
I had a really good weekend, first I made some rough looking but functional paddock stands and between saturday and sunday I got the engine mounted in the frame, I'm so happy after 3 years not working, and 2 with the engine in pieces it starting to look like a bike again!
-I need a to redo the wiring and get a headlight for it, there's a place locally that sells some 5 inch round LED headlights with high and low beam settings, I'm thinking of getting one of those since they draw about 30w on high a bit less on low beam.
-The bike doesn't have any brakes for the moment, the rear has new brake pads, but I got to reinstall the linkage and lever. The front hydraulic lines are are garbage, so I need to redo those, I also have new front brake pads.
-The carbs are in pieces.
-The clutch is out, but I have new fiber discs and HD springs.
-Need to reinstall the airbox.
-Fix the front fender since it's all dinged up and find a solution for the rear.
And that's about as much as I have left before a working bike.
1975 CB400F owner
« Reply #145 on: June 06, 2016, 02:46:52 AM »
my fuel tap is leaking..and karbs dont hold the fuel line..one is overfloting and one is  mostly dry..
but you are on the right vay....to the road..
Offline Jore
« Reply #146 on: June 06, 2016, 09:57:05 PM »
Thanks strynboen, it's missing some things but yes, it's getting there.
1975 CB400F owner
