Author Topic: Timing light issues  (Read 2529 times)
Offline Paul Lowe
  • If you like then it is good...
Timing light issues
« on: April 03, 2015, 04:42:23 PM »
Have a standard clamp type timing light I have used over many years. It only works intermittently on my cb750 k1?  Tested it on other systems and it is fine.
Have new coils points and plugs.  Bike has had issues but can't fix without timing??
Is the wasted spark system part of the problem?  Have swapped most things but still same same...
I wanna vroom!
Paul
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Online scottly
Re: Timing light issues
« Reply #1 on: April 03, 2015, 06:49:39 PM »
The wasted spark system on these bikes produce a different polarity spark for the 2 cylinders on each coil.  My timing light has an arrow on the clamp that points towards the spark plug. Try reversing the clamp, or moving it to the other wire from the same coil.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: April 03, 2015, 06:51:12 PM »
That has worked for me so I'll second that
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: April 03, 2015, 07:47:21 PM »
I'll third, just to make Paul feel silly. (Also I had the same problem, got mad, and then figured it out...)
--Evan
1975 CB750K "Rhonda"
Offline Paul Lowe
« Reply #4 on: April 03, 2015, 08:18:34 PM »
Not feeling silly, did that still no flash!
Occasionally it flashes but never at high revs?
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Online scottly
« Reply #5 on: April 03, 2015, 08:31:47 PM »
Is it the same for both coils, or just one? If just one, you may have an issue with the points that feed that coil. If both, try powering the light from a separate battery.
Online Deltarider
« Reply #6 on: April 05, 2015, 01:43:48 PM »
The HT lead should be clean and free of any grease. If not clean, clean with some alcool. The clamp (caution: don't drop it, they are fragile) should be closed fully. If there is no reading the clamp should be - how do you say? - turned around? This is for polarity reasons. External battery isn't a bad idea either,
« Last Edit: April 05, 2015, 01:46:57 PM by Deltarider »
Offline Paul Lowe
« Reply #7 on: April 05, 2015, 02:29:34 PM »
Leads new, points swapped, clamp ok, turned all ways still no good?  Put timing light on car and it's a nice consistent disco light!  WTF
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline scunny
  • don't call me expert
« Reply #8 on: April 05, 2015, 02:45:25 PM »
move bike from garage, replace with car. dance party. bugger too old for that #$%*.
had the same problem years ago on my 500, never did find a solution, shall wait for updates.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
DH
« Reply #9 on: April 05, 2015, 04:09:45 PM »
This seemed hazardous to me when I heard it but, a long time ago, maybe on this forum, somebody had this same problem.
The solution was to wrap tinfoil around a section of the plug wire, then place the clamp over that. Not Saying it's right, will work,
whether or not its hazardous, or anything else. Maybe someone with more knowledge will add? I've not tried it, but would hook it all up with the engine off, obviously, then see if it makes for a better "signal"(?) Anyone know if there's any truth to this?
Offline Paul Lowe
« Reply #10 on: April 05, 2015, 06:12:50 PM »
Will test and report. Maybe I should wear a tin foil hat too...
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline MoMo
« Reply #11 on: April 05, 2015, 06:16:13 PM »
or maybe hire The Tin Man to do it
Online scottly
« Reply #12 on: April 05, 2015, 06:46:15 PM »
Try powering the light from your car battery with the clamp on the sohc...
Offline evanphi
  • Apparently I'm an
« Reply #13 on: April 05, 2015, 06:49:08 PM »
This could be fun... A low battery would cause this problem...
--Evan
« Reply #14 on: April 06, 2015, 03:57:29 AM »
Interesting, my cheap timing light never gave me trouble.
Just yesterday I tried it on the K3F, just turning the engine over with the starter to see if I have spark on every cylinder.
Offline Rgconner
« Reply #15 on: April 06, 2015, 08:41:59 AM »
Even if it is not, you will get a more steady light, less jitter. Presumably because of the fluctuations in power from the alternator.
1975 CB550K aka "Grease Monkey"
Offline becken
« Reply #16 on: April 07, 2015, 05:21:53 AM »
with one timing light I had, when using a separate battery, it wouldn't work right until I ran a jumper wire from the battery negative to a ground on the bike
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline Vinhead1957
« Reply #17 on: April 07, 2015, 11:39:47 AM »
One light I had a direction on the pickup towards the spark plug
