Author Topic: 71 CB500 Assembling Sprocket Carrier - Question  (Read 782 times)
Offline Skowinski
« on: April 05, 2015, 06:00:04 PM »
Does this seal need to be tapped down into the steel ring here?  It measures 1 mm larger in OD than the ID of the retainer ring it is sitting on, so seems too big, and the sprocket cover looks like it would hold it in place anyway.  Only looks like it could go in a few mm before it would be on the shoulder on the bottom of the spacer it fits on.
Offline nicks2319
  • Youngstown, OH
Re: 71 CB500 Assembling Sprocket Carrier - Question
« Reply #1 on: April 05, 2015, 06:16:52 PM »
There's a plate that goes over that, that keeps the seal in place. It's the plate that covers the sprocket.
Offline Skowinski
« Reply #2 on: April 06, 2015, 07:11:41 AM »
Thanks Nicks, so from your answer it seems the seal is not driven into the retainer ring, as I suspected?
This is the first old Honda I've built, and it has some odd designs I've not run across before, like this.
Offline nicks2319
  • Youngstown, OH
« Reply #3 on: April 06, 2015, 11:05:59 AM »
Correct. The seal with fit snug into the cover plate.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=lieol8ua8ic5atn367da7a8793&/topic,60973.0.html
« Reply #4 on: April 06, 2015, 11:24:52 AM »
i hate all this v-w.... vords
