Author Topic: Working on 81 CB900C  (Read 1983 times)
Offline J R
« on: April 07, 2015, 08:06:57 AM »
Hello Everyone
I am new to this site and I have only had my bike a few months now and when I got it the clutch was slipping. Now I have the new clutch in but I cant find torque specs for the springs anywhere. Any help would be appreciated. Also Should I use anything on the new gasket for the clutch cover or just put it on dry.
Thanks J R
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Working on 81 CB900C
« Reply #1 on: April 07, 2015, 09:29:24 AM »
Can't  help you with torque specs. Gasket should go on dry though.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: April 07, 2015, 11:32:45 AM »
Most likely 6-8 ft.lbs if they are 6mm bolts
Offline J R
« Reply #3 on: April 07, 2015, 02:19:45 PM »
Thanks for the info!!! I'm pretty sure the bolts are 8mm but ill have to double check once I get home. Would that mean that they need a little more torque
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: April 07, 2015, 02:34:49 PM »
Not specific to that bike, but here are Honda's general torque specs
http://www.salocal.com/sohc/tech/torquetable.htm
Offline MoMo
« Reply #5 on: April 07, 2015, 05:23:40 PM »
The thread size is 8mm?   If so, 14-16 would be in order.   Most clutch spring retainers on Hondas are 6mm thread
Offline J R
« Reply #6 on: April 07, 2015, 07:47:26 PM »
Thanks MoMo and Tugboat for all of your help. You are right MoMo the bolts are 6mm. So I'm going to give it a try within the next few days (if work will allow) and let you know how it goes.
Thanks again
J R
Offline kennyw
1982 CB750C
