Author Topic: Carbs on cb500 '72 surging  (Read 817 times)
Offline vonvendetta
« on: April 07, 2015, 03:26:15 PM »
So like many, I am back with carb questions.
They've been fully cleaned, synced and has brand new plugs.
Using velocity stacks
Did 3k service
Needle to 5th position
110 jets
I had a bad surge at low rpm unless I punched the gas. And the old plugs looked like it ran rich.
I now have my air screw out 2 1/2 turns (1 1/8 when started this) and it has smooth pick up for the most part now.
Should I change the jet size smaller again to bring the air screw back in?
« Last Edit: April 07, 2015, 03:34:35 PM by vonvendetta »
Offline vonvendetta
Re: Carbs on cb500 '72 surging
« Reply #1 on: April 07, 2015, 04:19:59 PM »
After more searching, should I change my pilot jet to something smaller, believe they are 40 currently; or move my clip to 4th position?
« Last Edit: April 07, 2015, 05:57:45 PM by vonvendetta »
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #2 on: April 08, 2015, 08:51:08 AM »
Surging in a non governed engine is the result of lean, which will make the engine 'hunt'.    Set carbs to factory....if the surges continue, spray the intake connections with a mineral oil, mystery oil, something that will smoke when fired in the cylinder because air is leaking in from somewhere.  Eliminate the obvious before getting into carb issues...which you shouldn't have if they are set to stock and clean.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
