Author Topic: oil pressure switch  (Read 689 times)
Offline natron602
oil pressure switch
« on: April 09, 2015, 05:15:32 PM »
Ok I can't seem to find info on replacing this anywhere. ordered the replacement because it's leaking oil but...do I have to drain the oil to replace it or can I just be quick?
In an effort of thread conservation....anyone happen to know what could be causing my #1 spark plug to keep coming loose?
Offline Airborne 82nd
Re: oil pressure switch
« Reply #1 on: April 09, 2015, 05:30:09 PM »
They are not all the same and You don't say what you have or I missed it. :)
Offline natron602
« Reply #2 on: April 09, 2015, 05:36:55 PM »
I'm usually pretty good about that but... ya know. 1975 cb550k
Offline toolguy
Offline natron602
« Reply #4 on: April 10, 2015, 09:34:46 AM »
Look here.
http://forums.sohc4.net/index.php/topic,144354.msg1642681.html#msg1642681
I already have the part. I just need to know if I'm going to have to drain $30 worth of oil two weeks after my last oil change to replace it.
Offline Restoration Fan
  • My wife will never call me
« Reply #5 on: April 10, 2015, 09:55:48 AM »
Is the oil pressure switch in a different place on the 550 than it is on the 750?  On my 750, the oil pressure switch is to the right of the cam chain tensioner and starter cover.
While there's oil in that area, there shouldn't be a lot so you should be able to quickly remove the switch and put a new one in with a minimum of oil loss.
Now, if you're talking about the neutral switch that's on the bottom of the engine, you're going to see a lot of oil come out of there because whatever hasn't been returned to the oil tank via the scavenger line is going to be in the bottom sump of the engine and will want to leak out.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: April 10, 2015, 09:58:57 AM »
Just remove and replace, no spillage.
550= wet sump.
Offline natron602
« Reply #7 on: April 10, 2015, 10:19:03 AM »
550= wet sump.
Easy breezy. Thank you, sir.
Offline mihai.i
  • Sorry for my english!
« Reply #8 on: April 10, 2015, 11:58:28 AM »
I use a oil pressure switch from an Honda CBR 954...also it fits 929 and others.
Just replace it without oil change. Be careful with the torque for the thread!
« Last Edit: April 10, 2015, 12:00:36 PM by mihai.i »
Honda Cb550k 1978
