Just to add for anyone looking to do this. If you are looking for a cb900 starter online, you'll notice they are listed as the same starter for the dohc 750. As stated earlier, some are 800 watts and some are less. They are the same Honda part number and same Mitsuba number : SM-220. It came in 700w and 800w.
Most of the 750's seem to have the 700w version, and all the cb900 starters I came across were 800w.
Yes, they say in small casting letters what size they are but you can't really see that when browsing on eBay. Luckily, the 800w version has a big "438" cast into it. It also has a larger cylindrical shape that the 438 sits on. It also has the fine print curved around the cylindrical shape. See pics below:
Standard sohc cb750 SM-226 (600w or 0.6kw)
- small cylindrical center
- straight fine print
Dohc cb750 79-82 SM-220 (700w or 0.7kw)
-same small cylindrical center
-same straight fine print aside from the wattage
Cb900-1000-1100 c/f SM-220 (800w or 0.8kw)
-larger cylindrical center( probably because of larger inner bearings)
- fine print curved around center
- large "438" stamp
As for the reduction gear:
Sohc 750 has 16 teeth on the small gear and 47teeth on large gear.
Dohc 750-900-1000-1100 all have 15 teeth/46teeth.
Don't think about goldwings, shadows, or cbx as they allegedly spin the other way
