Author Topic: 73 honda cb 750 wont start  (Read 5939 times)
Offline njf33
« on: April 13, 2015, 02:16:22 PM »
I have a 73 honda 750 cb. It sat through the winter . I replaced battery. Tank has over quarter tank oil levels good bike shows no signs of leaking any fluids. I tested the silonoid it has power rectifier has power everthings grounded properly. Bike when starter button is engaged starts up like it wants to start but just doesnt get there. Spark plugs are getting spark. Somethings ive noticed are the gauges oil nuetral etc dont light up only lights that work on bike are tail lights. A similar story said signs point to ignition switch.  So next im going to test that make sure its getting power and also make sure engine is getting gas. Anyone with similar issues all and any advice would be appreciated.
Offline Chachi
Re: 73 honda cb 750 wont start
« Reply #1 on: April 13, 2015, 02:18:09 PM »
To rule it out... try on reserve. Might be surprised. Visual tank level can be deceiving.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline njf33
« Reply #2 on: April 13, 2015, 02:26:07 PM »
Good call I will try that. Its those little things sometimes that slip the mind. Thanks.
Online Stev-o
« Reply #3 on: April 13, 2015, 02:29:12 PM »
Check the voltage on your battery, should be 13+V if fully charged.
« Reply #4 on: April 13, 2015, 02:53:43 PM »
yuup! +1
"This is my CB. There are many like it, but this one is mineā€¦"
Offline njf33
« Reply #5 on: April 13, 2015, 03:38:21 PM »
Battery is fully charged.
Offline Allen Statu
« Reply #6 on: April 13, 2015, 03:48:30 PM »
yuup! +1
Same thing happened to me. I had a new battery and checked a number of electric parts. Grounds, solenoid (replaced), and rectifier/regulator, flash relay (for some lights). But I jumped my bike with a portable charger, and it started right up. I then started charging my battery with a tender, until I got a better quality battery.
Also similar thing with my lights. Only the brake light would go on, but when I had the ignition in park.
'73 Honda CB350F
Online Stev-o
« Reply #7 on: April 13, 2015, 03:50:19 PM »
Checked with voltmeter?
Offline njf33
« Reply #8 on: April 13, 2015, 05:37:59 PM »
Yes.
DH
« Reply #9 on: April 13, 2015, 09:22:24 PM »
+1 on a charged battery, but is this a NO CRANK issue or a CRANKS but WON'T START issue?..just for verification :)
Offline njf33
« Reply #10 on: April 14, 2015, 07:22:49 AM »
Cranks but wont start.
Offline MoMo
  • Ride like you're invisible
« Reply #11 on: April 14, 2015, 07:28:02 AM »
so you have spark,  good compression and fuel in the correct ratio?   You've eliminated spark, probably has good compression because it ran before, so that leaves fuel.  Turn petcock off, drain fuel from carbs and let "fresh" fuel  flow in. Should start...Larry
« Last Edit: April 14, 2015, 07:33:37 AM by MoMo »
Online Stev-o
« Reply #12 on: April 14, 2015, 07:29:58 AM »
+1 fuel. Have you checked your petcock for possible clog?
Offline njf33
« Reply #13 on: April 14, 2015, 07:38:29 AM »
Thats on list for tommorow that and checking contact on starter and ignition switch off next 2 days gonna try and git r done. Keep you guys posted.
Offline iron_worker
« Reply #14 on: April 14, 2015, 08:06:35 AM »
It will be 13+ immediately after charging. Let it sit for a few hours and then test the voltage to see if it maintains at least 12.6V. f it drops below this then it's probably bad.
However, sounds like by the amount of cranking you are able to do that the battery is not the issue. Are you sure there is spark on all 4 cylinders?
IW
Offline Vinhead1957
« Reply #15 on: April 14, 2015, 08:22:05 AM »
+1 on changing the fuel, remember the bowls.  Bad fuel even smells different. More like varnish.   The biggest problem with these bikes is fuel, old fuel and the effects of old fuel
Offline njf33
« Reply #16 on: April 14, 2015, 12:50:52 PM »
Yes spark on all 4 cyl. The more I read about the fuel the more im betting on that would make scense sat all winter. Im going to start with that so at least I can rule it out.
Offline mystic_1
  • 1970 CB750K
« Reply #17 on: April 14, 2015, 04:15:10 PM »
Yeah if the bike sat all winter with only 1/4 tank of gas, it's likely absorbed a bunch of water from condensation during temperature changes, plus it oxidizes "faster" due to the smaller ratio between the exposed surface area and the total volume.
If you top off the tank with good gas that should dilute the bad enough for the bike to run and ride, then you can burn it off.  Or, tap it out and dump it into your car's tank where it'll dilute even more.  Or run it in your lawn mower, etc.
mystic_1
- John Augustus Shedd
Offline MoMo
« Reply #18 on: April 14, 2015, 09:31:27 PM »
Offline njf33
« Reply #19 on: April 15, 2015, 12:41:35 PM »
Fuel filter clogged drained old gas out of carb changed oil babys purring now. Thanks for all the advice and helped very much appreciated now time for a cruise.
Online Stev-o
« Reply #20 on: April 15, 2015, 04:09:47 PM »
I'm betting KILL switch is not allowing 12v to coils
You lost that bet, you owe me an IPA!
Bingo!
Online Stev-o
« Reply #21 on: April 15, 2015, 08:10:47 PM »
On its way. Cans or bottles?
Prefer bottles.  Thanks!
