Author Topic: Cafe/brat seat with hinges or easy access?  (Read 1745 times)
Offline xtravbx
« on: April 14, 2015, 07:31:09 PM »
Hey guys. Anyone have examples of a hinged seat or easy off brat or cafe seat? All the examples I find the seat/pan is screwed or bolted to mounts in the frame. Am I incorrect?
I'm having s hard time figuring out in my head how I'd like to mount my seat. I'm using a standard hoop that I plan to weld in with slugs. I have a brat seat I'll be attaching.
But in order to get to underside/electronics/battery I have to unbolt it..?
Re: Cafe/brat seat with hinges or easy access?
« Reply #1 on: April 14, 2015, 08:17:15 PM »
If you want the low profile of a Brat, that's the best way to do it.
Offline xtravbx
« Reply #2 on: April 15, 2015, 05:48:03 AM »
Appreciate it!
Offline KirkBurner
« Reply #3 on: April 16, 2015, 12:00:23 PM »
its not the greatest... but its a hinged cafe seat...
Offline wowbagger
  • Not much of an
« Reply #4 on: April 16, 2015, 01:01:23 PM »
Mine uses the stock seat pan and still has enough padding to be a comfortable ride. Sorry for the mid-build photos.
Offline CB_Jeff
« Reply #5 on: April 16, 2015, 02:28:46 PM »
Check out Frankenbike's mounting blocks.
http://www.fb-stuff.com/fb-stuff-store.html
I used a set on my K6 cafe project and they worked great.... and solved many problems....
« Reply #6 on: April 16, 2015, 05:17:43 PM »
They may have been an early production version, but my rubber seat mounts failed repeatedly (split in half) on the side next to the oil tank - likely due to heat exposure.
