Author Topic: Swingarm Bushings  (Read 5913 times)
Offline mcinturff
  • Less Old-Timer
Swingarm Bushings
« on: April 15, 2015, 09:35:22 AM »
I'm going to tear down my 750 for paint and do some "while you're in there projects".  Can anyone give me some approximate dimensions for doing some bronze swingarm bushings?  I need some measurements so I can order some oilite and have my buddy machine them when the time comes.  Need i.d., o.d., length, and flange diameter and thickness.
74 CB750
Offline Davez134
Re: Swingarm Bushings
« Reply #1 on: April 15, 2015, 10:31:23 AM »
Do you know that the bushings you describe are readily available? If so, disregard. I understand guys like making stuff, just wanted to make sure you knew ya can buy proven, quality bushings. Sorry that I cannot offer dimensions, as mine are already installed.
Offline Powderman
« Reply #2 on: April 15, 2015, 11:38:08 AM »
And buy them cheaper than you can make them, unless you work for free in which case I have a bunch of stuff you can make for me.
$25 shipped, I've purchased from this guy in Germany and they are good units:
http://www.ebay.com/itm/Honda-CB-250-360-400-500-550-750-Four-swingarm-bronze-bushing-set-bearing-new-/251851928293?hash=item3aa38b72e5&vxp=mtr
Wobbly
« Reply #3 on: April 15, 2015, 12:03:51 PM »
I upgraded last year to a swing-arm-needle bearing set (Parts Plus, made in Japan). Just another option one might consider.
Offline neurotoxin312
« Reply #4 on: April 15, 2015, 12:21:11 PM »
Are these bushings good quality? I've heard getting oil impregnated bronze bushings are better?
Offline mcinturff
  • Less Old-Timer
« Reply #5 on: April 15, 2015, 02:18:38 PM »
I am well aware that pre-made bushings exist.  The fact is that many people who have bought these are dissatisfied with the fit.  I can have the machining done for free, and have a part that fits MUCH better than something I can buy online.
74 CB750
Offline mcinturff
  • Less Old-Timer
« Reply #6 on: April 15, 2015, 02:19:11 PM »
How is the fit?  I imagine anything is better than the stock design.
74 CB750
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #7 on: April 15, 2015, 02:37:18 PM »
Oilite is relatively soft and will wear quickly. Better to use proper bearing bronze which you can get in round bars of different diameters from any bearing supplier. I have a lathe and have used this to make bushings for a number of bikes with good results. Bearing bronze is also great for making bushings for worn pivot holes on brake and shift levers.
Offline DaveBarbier
« Reply #8 on: April 15, 2015, 03:16:11 PM »
I would message Hondaman about this. I'd be surprised if he doesn't have all these measurements.
1978 Honda CB550K
« Reply #9 on: April 15, 2015, 04:24:55 PM »
How much..?
Offline CBDee
« Reply #10 on: April 15, 2015, 05:48:37 PM »
Not necessarily an upgrade. These tend towards rusting out. You definitely don't want to power wash the bike with these bearings. Do a search before you decide there might be better alternatives. Jfyi
Sent from my Old & Busted PC using Myindexfingers
« Reply #11 on: April 15, 2015, 06:08:01 PM »
Hmmm, lots of other bikes have them, I have a GSX1100 swingarm sitting next to me that all needle bearing, its out of a 1984 model and still perfect... ;)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #12 on: April 15, 2015, 08:38:58 PM »
Who powerwashes a vintage bike?
I'll powerwash my dirt bike, avoiding anything that rolls or turns, but that's it. No Bueno.
I have a motorcycle problem.
« Reply #13 on: April 15, 2015, 08:51:40 PM »
I don't even power wash my cars, it gets water into places it never gets by itself, great way to rust the damn thing out.... ;)
« Last Edit: April 15, 2015, 10:37:20 PM by Retro Rocket »
Offline CycleRanger
  • No comment about being an
« Reply #14 on: April 15, 2015, 09:46:45 PM »
I've installed three sets of bronze bushings from Kenosha Kid in Germany.
Good quality, good price, quick shipping.
Wobbly
« Reply #15 on: April 16, 2015, 02:59:18 AM »
@ retro
I believe, I bought these in Germany. Here is an example on Ebay: http://www.ebay.de/itm/Honda-CB-750-K1-K6-69-76-CB-750-F1-F2-77-78-Schwingenlager-Nadellager-Set-/191554015180?pt=LH_DefaultDomain_77&hash=item2c99824fcc
If you consider getting one, I am at a domestic U.S. military address in Germany and can help.
I believe that they are an upgrade, and this opinion is generally shared across all forums independent from the brand of motorcycles. It's one of those little improvements  that nobody can see--my favorite kind. They have been a standard upgrade in Germany for decades. As you know, the newer bikes use them too. I had them installed last year (I turned in the swing arm because I had it powder coated at the same time) while I installed tapered roller bearings in the front. Together with my Konis and Bridgestone tires, I think handling is at its best, leaving the look of the bike undisturbed, keeping it contemporary. But that is just my opinion.
Offline Bootsey
« Reply #16 on: April 16, 2015, 03:17:48 AM »
I have those kenosha_kid bronze bearings - Installed they measure about 21.45mm inner diameter.
I've recently been speaking with Hondaman, and he kindly offered up some of his wisdom.  His suggestion is that the collar to bearing clearance should be .0008" to .0012"  & the collar should stick out .002" either side of the bushings, as it compresses when installed and tightened.
Offline flatlander
« Reply #17 on: April 16, 2015, 04:13:34 AM »
i'm with wobbly re. the needle bearings. installed them early last year.
i don't power wash the bike but of course, time will tell....
Wobbly
« Reply #18 on: April 16, 2015, 07:03:44 AM »
As a side note: Everyone is free to "believe" what they want. I do not believe that bronze swing-arm bushings need less maintenance than needle bearings. Needle bearings are more difficult to install properly, but they are generally seen as an improvement over bronze bushings. Apparently, Honda thought so too. I simply wanted make aware of this alternative.
« Reply #19 on: April 16, 2015, 03:11:00 PM »
@ retro
Thanks for that, I may just take you up on that, I actually have a link to that same kit, but its being sold on from the US and its quite a bit more expensive... ;)
Offline Phoenix
« Reply #20 on: April 16, 2015, 06:24:27 PM »
I read in a previous thread that this is not a proper use for roller bearings.  They pointed out that the small amount of rotation and back and forth action is not conducive to their design.  Just sayin.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
« Reply #21 on: April 16, 2015, 06:49:39 PM »
Well what about all the 35 year old bikes that still have perfectly good roller bearings in their swingarms...?  I have one such example right next to me as I type, not to mention the thousands of other bikes since that use them, I'll side with the engineers that designed the system rather than internet gossip and opinion... ;D ;)
Ok, after typing that i removed the cap and spacer from the swingarm and rotated the swingarm on the pivot bolt about 3 inches, the small size of the needle rollers means that they actually spin more than you'd think, thats probably why none of them have worn unevenly....
« Reply #22 on: April 16, 2015, 07:30:17 PM »
Umm...sorry to differ, but...no. Oilite is 26,000 PSI strength (you can also check all these numbers in the "Machinery's Handbook", any version). The cast composite bearings Honda sells are 8,000 PSI, the phenolic OEM parts were 6,000 PSI, and the original Zamac on the K0/K1 frames was just 3400 PSI strength.
I have built hundreds of swingarms with the Oilite material, and they last a lifetime for the effort. I still offer it as a service, and give a Lifetime Warranty on the work, as the engine will wear out long before the finished arm will.
The SAE660 bronze is even harder, at around 30,000 PSI strength. I make racing arms and the smaller bikes with these, as the smaller bikes had smaller collar diameters and can use some extra strength.
The dimensions vary per year/model of the bike. There are 3 ID sizes on the swingarms, ranging from 1.0420" to 1.0444", the collar ends (when brand new) are either 0.8440" or .8444", depending on which type you have (none are available today, so you must either refurbish your old one to a smaller OD and make custom bushings, or make a new collar and fit bushings to that). There are also 2 different lengths in the 750 arms, depending on year.
All together, there are 12 possible combinations of STOCK parts. As your collar will either need to be polished to a new, smaller OD to make it round (or even smooth) again, there are no bushings that you can buy that will be a direct fit.
The clearances: the difference between the OD of the collar and the ID of the bushing is .0008" to .0012" max. With Oilite bronze, the fit interference should be .0004" to .0008", lest the bearing partially crush and deform during installation. Chances are, you will also find the hole(s) in your swingarm to be WIDER at the outside ends as compared to the inside, by somewhere between .0002" and .0012", depending on how hard the bike was ridden and how well it was greased over the years. The holes are also often oval along the axis of the bike, with the widest portion toward the engine on the chain side and the brake on the left.
Just a few of the words I give to the wise weho wish to make bushings for these: I've made hundreds and hundreds of them!
:D
« Reply #23 on: April 17, 2015, 01:32:57 AM »
Mark, what is the collar made from?  Is it case hardened?
« Reply #24 on: April 17, 2015, 07:11:01 PM »
The collars were case-hardened from Honda until sometime during the K3. Then they became polished, but not extra-hard. In the last of the 77-78 bikes they were hard again. Interestingly, it seems to make almost no difference in wear rates, unless things are not greased. Then the hard ones scratch worse but hold their OD better. The ones I have made for me are not hardened now, but with Oilite there isn't much need for it, as even when the owner forgets an interval, the oil in this bronze will "kick in" if it gets hot and needs some help in the short term.
