The SOHC/4 World Tour is in under way.
the only issue i see with mounting it directly to the inner plastic fender is stress and cracking of the inner fender from vibration.why not make new holes in the fender, and use the existing frame cross brace holes to mount the fender to, and locknut the underside of the fender. at least its well supported here, and can support the weight of your tail lights....
Have a look under the rear guard you want to chop, you can see that there is a subframe joined to the guard, separate the two, cut the guard and rejoin, looks neat and completely stock, it will bolt up the same as a stock guard....
Quote from: flybox1 on April 16, 2015, 02:29:29 PMthe only issue i see with mounting it directly to the inner plastic fender is stress and cracking of the inner fender from vibration.why not make new holes in the fender, and use the existing frame cross brace holes to mount the fender to, and locknut the underside of the fender. at least its well supported here, and can support the weight of your tail lights....I was planning on doing both. I would use that frame cross brace to mount the fender. Quote from: Retro Rocket on April 16, 2015, 04:02:03 PMHave a look under the rear guard you want to chop, you can see that there is a subframe joined to the guard, separate the two, cut the guard and rejoin, looks neat and completely stock, it will bolt up the same as a stock guard....i'm not sure I follow what you're suggesting.
What I did is probably not want you want but its also reusing stock fender and making new mounting brackets. I added taillights but don't have picture right now.
Retro Rocket, you're a genius! That looks perfect. I'll look into this tonight!
Here's a look from underneath.
Yup, me I'd ebay up a decent fender with the right substructure to bob and leave the stock one as a fall back just in case.mystic_1
i didn't have a chance to look at it tonight. but i'll find away. i'll probably not buy another fender, i'm trying not to spend anymore on this project. Somebody is going to get cut this weekend!
