Hi,
I removed the whole assembly and the bracket on which the pads are mounted was indeed completely stucjk. So I cleaned it and put it back with the adjusting screw.
Trouble begins when I changed the brake pads: impossible to get the wheel turning freely and when Inapply brakes, the pads get stuck on the disk. I had. To put the old pads back on. Turning the adjusting dcrew doesn't change much. Even with the old pads, I can't get the wheel to turn freely. I don't know what I did wrong.
Does anyone have an idea?
Thanks,
