Author Topic: Carpy's Bobbed Rear Fender  (Read 543 times)
Offline dgilling
« on: April 22, 2015, 09:25:30 PM »
Has anyone used this?  it said "Fits any 69-78 CB750".  the flat piece looks like it will mount up just fine after I drill some holes but the side mounts do not line up at all.  Am I missing something?
Here you can see the gap on the top if I line up what looks like the side mounts
Here is if I line up the top, impossible to use the side mounts.
Here is a look from underneath.  I marked the bolt hole.  This is as far back as I can push the fender and still be able to mount the top holes
Re: Carpy's Bobbed Rear Fender
« Reply #1 on: April 22, 2015, 09:45:04 PM »
That looks like its made to suit 69-76 K frames, the 77-78 K and all F models have a 2 inch longer frame at the rear.
Offline dgilling
« Reply #2 on: April 22, 2015, 10:46:43 PM »
Fantastic
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: April 23, 2015, 01:59:23 AM »
I wrestled with the same problem a while ago. In the end I used an old K fender on my F, and bobbed it at the front. Yes I lost the rolled edge, but fitting the tail light hid most of that and also added rigidity. It's on the second page of my build thread.
Incidentally, the fender I used was from a much earlier K than my F, and whilst the side mount holes didn't line up there was much more area on the sides to re-drill than the one in your pic. It looks like the Carpy one is made to fit, but does not replicate the dimensions of the original.
Build threads:
1977 CB750 F2
1958 Norton Model 99
