Author Topic: $200 CL buy  (Read 22436 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #225 on: June 05, 2015, 03:37:54 PM »
So bought em. Fit great. First ride after some backfire...too rich?
http://forums.sohc4.net/index.php?topic=148475.0
Backfire after clamp and boot replacement
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #226 on: June 06, 2015, 07:59:13 AM »
Bought Iowa Blues little sister today for $300
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #227 on: June 06, 2015, 10:04:52 AM »
I tried timing the bike yesterday and am struggling a bit. Dynamic instructions say rev bike at 2500 and put it between the lines. Should they line up in both or just 1-4
Gus, Austin, MN.
Offline chewbacca5000
  • I polish covers!
Re: $200 CL buy
« Reply #228 on: June 06, 2015, 10:11:30 AM »
I believe you should be a the F mark at 2,500, and yes both 1,4 and 2,3 need to line up.  You are moving the timing light clamp from 1,4 to 2,3 correct?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #229 on: June 06, 2015, 10:51:00 AM »
Ya. Gonna give it another go today
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #230 on: June 06, 2015, 12:32:48 PM »
If 1,4 is set move the timming light to 2,3.  2,3 Has a sub-plate that you can use to make the necessary adjustment.  It may take a couple tries as it has a tendency to move a bit when you tighten them up.
Make sure you double check your point gap.  I think you want them to be .14" at the widest point.  You will need feeler gauges for this.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #231 on: June 06, 2015, 12:58:35 PM »
I have elec ignition. Sub plate? Never heard of it...where is it located?
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #232 on: June 06, 2015, 01:23:03 PM »
Sub plate refers to points.  What brand electronic?  Most are not adjustable.  Could also be the advance needs cleaning / oiling.  Also the advance stud needs to be true or you can't get your timing correct no matter what.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #233 on: June 06, 2015, 01:27:43 PM »
Dyna. Gonna try and get it out and get it as close as i can
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #234 on: June 06, 2015, 01:40:50 PM »
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #235 on: June 06, 2015, 03:06:44 PM »
Looks like there are Allen bolts holding in the ignition, but not sure if they can be changed
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #236 on: June 06, 2015, 05:32:15 PM »
Bolt style does not matter you can move the plate forward and back to set timing.  At idle should be on F mark at 3k between the two hash marks.  I would not try to adjust those black pickups and there is no telling what might happen.
I got the original DYNA and it screams!  You know the one with the box on the side.  I think I am going to ditch it get points and the Hondaman setup.  You have electronic and and adjust your pairs individually.  It is dirt cheap compared to other setups as well.
The newest dyna lets you do all types of things, but price is $400.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #237 on: June 06, 2015, 05:33:29 PM »
Why would i be able to do it at 1-34 but not 3-4
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #238 on: June 06, 2015, 05:43:29 PM »
The black boomerang things are set from the factory.  You are pretty much stuck with what you have.  How close are you?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #239 on: June 06, 2015, 05:47:03 PM »
Quarter inch on 2/3
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #240 on: June 06, 2015, 05:51:53 PM »
Quarter inch on 2/3
Can you go back to points so you can troubleshoot further?  It is the Dyna, the mechanical advancer, or the stud that the advancer rides on.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #241 on: June 06, 2015, 05:54:08 PM »
Nope. Right now im waiting on emulsion tube. Drilling them out i believe has had a negative affect on performance as i am starting to get pops and irregular running. Gonna park it fir now and ride the harley till i get more parts.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #242 on: June 07, 2015, 03:13:11 PM »
If the advance needed cleaning or oiling would it work for one and not the other? Or would cleaning advance help them both line the way they should.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #243 on: June 10, 2015, 07:39:24 AM »
The black banans are adjustable and the timing is now set really well. Waiting on emulsion tubes, and plan on getting my float situations straightened out. The POs and myself bent the floats back instead of the tang. I plan on bending them back to where they need to be then readjusting for proper float height.  then hopefully I will have a good runner!
Gus, Austin, MN.
