Author Topic: $200 CL buy  (Read 22546 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #175 on: May 26, 2015, 04:10:19 PM »
Clanky Seems loudest coming from clutch cover. Used scope
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline chewbacca5000
  • I polish covers!
Re: $200 CL buy
« Reply #176 on: May 26, 2015, 05:22:39 PM »
Sounds pretty good.  I would not worry about the rattle for now.  If you want to check it make sure you have a spare clutch gasket on hand.  Be very careful taking tension off lifter plate as if you undo one or two all the way it will chip or crack.
Ride on!
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #177 on: May 26, 2015, 05:25:41 PM »
Ok cool. Adjust rappers and fly!
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #178 on: May 26, 2015, 05:26:20 PM »
Is there slumping on these sometimes? Now that ive run it a few times there is a light puddle of oil on the ground
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #179 on: May 26, 2015, 07:07:22 PM »
You might have over filled.  If yours is a true 72 you might want to turn the chain oiler down or off as well.  There is a little screw you can turn in to reduce this.  Is it right near the kickstand?
Also check all oil hoses on engine and tank.  Especially the ones behind the tank you can't see.
Did you give it a tune up and set the points and timing yet?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #180 on: May 26, 2015, 07:08:34 PM »
Gonna try to do that in the next few days. Many of the rapper covers are hosed
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #181 on: May 27, 2015, 06:23:07 PM »
A ride today:
Had a few minutes and convinced the wife to let me go for a spin. Started and shifted very well but had no getup at all. Tried adjusting clutch cable and carbs a bit...nothing.
Got home and dripped a bit of water on each pipe. 1 and 4 were not firing. Come to find out that the plug to the dyna timing came out for cylinder 1 and 4 again! I bet that'll change things. Im still a bit confused about which knob controls the idle but im sure its way to high now.
Also not sure if this is common, but fired with plug out of cylinder 1 to check for spark and the bike fired up. It was loud as hell from cylinder 1 with a Clack Clack clack.   Typical? Thanks guys...excited to ride tomorrow with all plugs firing...
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #182 on: May 27, 2015, 06:49:44 PM »
Think your doing A-Ok so far.  What is your idle?  The big knob on the top of the carbs sets initial idle which should be 1,200 to 1,800 depending on the year.  This is a start point.
Each carb has an air screw that should be 1 1/4 to 1 1/2 turns out from lightly seated.  You should have set your floats to 26mm with the new needle / seat combo you ordered.
As for power no 1,4 would do it.  Surprised if you made 40 MPH.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #183 on: May 27, 2015, 06:51:28 PM »
Is there one knob per two carbs? Right now i am 26mm and 1.25 out
Gus, Austin, MN.
Re: $200 CL buy
« Reply #184 on: May 27, 2015, 07:03:04 PM »
1 idle adjust screw for four carbs.  You've had a CB before, you've never adjusted the idle??
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #185 on: May 27, 2015, 07:06:09 PM »
Ya i have but this one has two..cant remember the other one. Thanks for the help!
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #186 on: May 27, 2015, 07:07:08 PM »
I bought one with 2 adjust knobs.  I took the one on the right off and used the one on the left.  PO rubuid thing.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #187 on: May 27, 2015, 07:08:33 PM »
Ok cool. Thanks! One looks not original
Gus, Austin, MN.
Re: $200 CL buy
« Reply #188 on: May 27, 2015, 07:14:52 PM »
Really? I've never seen one with two.
  • I polish covers!
Re: $200 CL buy
« Reply #189 on: May 27, 2015, 07:17:30 PM »
Maybe he made a rack out of parts and put two knobs in there?  Some of the early rack have a place to install on the right or left.  How were they 40 years ago darn if I know.  I was in diapers.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #190 on: May 27, 2015, 07:41:32 PM »
Pics
Gus, Austin, MN.
Re: $200 CL buy
« Reply #191 on: May 27, 2015, 08:17:27 PM »
ok...that's really weird and totally not normal
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #192 on: May 27, 2015, 08:18:18 PM »
See im not crazy. I was confused!!! The metal one is stock, so im just gonna rip out the black bastard
Gus, Austin, MN.
Re: $200 CL buy
« Reply #193 on: May 27, 2015, 08:27:14 PM »
Ok, I stand corrected, you're not crazy!  The PO was.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #194 on: May 27, 2015, 08:28:23 PM »
Vindication!!!!!
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #195 on: May 27, 2015, 08:56:35 PM »
Vindication!!!!!
How many motorcycles do you have?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #196 on: May 27, 2015, 08:58:19 PM »
2 right now.
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #197 on: May 27, 2015, 09:01:29 PM »
2 right now.
Yeah your still sane.  Buy another 5 to 10 and join the madness!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: $200 CL buy
« Reply #198 on: May 28, 2015, 06:44:13 AM »
Hmmm... this makes me think I could swap the side my idle set screw is on? I have K1 carbs and a K5 tank, petcock is in the way of the idle adjust!
--Evan
1975 CB750K "Rhonda"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #199 on: May 28, 2015, 06:45:56 AM »
I think you can....they did the same thing both sides....
Gus, Austin, MN.
