Author Topic: What's this doohickey (at brake lever/MC)?  (Read 2449 times)
Offline mgzych
  • '75 CB550F
« on: April 27, 2015, 07:19:35 PM »
Just finished removing/lubing/replacing the clutch cable and lever on my '75 CB550F.  Figured I'd lube the lever on the right side, too.  When I removed the nut from the pivot bolt at the brake lever/MC, this little doohickey fell to the floor.
Forgive me if this is a trivial line of questioning, but...  What is it?  What does it do?  It looks like it may have held in place a "bumper" of sorts to soften the return of the brake lever?  This little cylindrical rubber bumper has deteriorated beyond recognition/usefulness.  Will I miss it?
Re: What's this doohickey (at brake lever/MC)?
« Reply #1 on: April 27, 2015, 07:44:36 PM »
Hold the rubberbuggerbabybumper in place..
 Keeps away the annoying vibrating leverthat would otherwise result.. Gets so bad you have to hold one finger on it..
« Reply #2 on: April 27, 2015, 08:25:00 PM »
Actually have never had a bike that still had that rubber piece...and the vibrating brake lever can send you into a trouble diagnosis frenzy :o   Once you get used to it, it is easy to ignore though.
Offline mrfish2
  • I might be a
« Reply #3 on: April 27, 2015, 09:30:04 PM »
So THAT'S whats been vibrating on my front end...
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Flyin900
« Reply #4 on: April 27, 2015, 10:03:43 PM »
Still available from Big Red. I would just cut a piece of rubber hose the same size. I did just replace it on my build and it was about $4.00 for a 1" piece of rubber. LOL
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline mgzych
  • '75 CB550F
« Reply #5 on: April 28, 2015, 03:25:43 AM »
Haha!  I knew I could count on someone here to know the technical name for it!
Yep, I'm sure that would have been me.
No hose in the house, but I'll be hunting for a piece of wire to strip and salvage the insulation from.
Thanks, all, for your willingness to help and  share with such a novice like me!
Offline Gman
« Reply #6 on: April 28, 2015, 02:36:44 PM »
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline mgzych
  • '75 CB550F
« Reply #7 on: May 01, 2015, 03:02:54 AM »
Ha!  It's amusing to see that blown up photo of a hacked off 1/2" long piece of rubber tubing labeled a "Genuine Honda..." with a part number.
Offline Powderman
« Reply #8 on: May 01, 2015, 07:01:36 AM »
If you looked closer you would see it is not a hacked off piece of tubing but a poorly molded separate piece with flanges on the ends. Still not worth $4
Offline CBDee
« Reply #9 on: May 01, 2015, 02:09:17 PM »
Just cut a piece of vacuum hose to fit. The plate holds it in place.
The part you get from Honda is nothing more then a rubber tube anyways. I Don't know where powderman got his, but the one I got was just a plain rubber tube.
« Last Edit: May 01, 2015, 02:16:19 PM by CBDee »
Sent from my Old & Busted PC using Myindexfingers
Offline SKTP
« Reply #10 on: May 01, 2015, 03:29:49 PM »
anyone have a pic of this thing in place? My PO must have totally removed this
« Last Edit: May 01, 2015, 03:54:06 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline mgzych
  • '75 CB550F
« Reply #11 on: May 01, 2015, 03:31:00 PM »
All done, with a piece of rubber hose. Thanks, everyone.
Offline Powderman
« Reply #12 on: May 01, 2015, 04:46:03 PM »
I didn't get one. I was referencing the picture from the link and the comment that it was nothing but a cut off piece of rubber tubing. It is clearly a molded piece with a lip on the end. Though a rather sh*tty mold it is not just a cut piece of tubing. I'm not saying a cut piece of tubing is not a better option financially.
Can't really tell but it looks like a few numbers molded in the near end of it.
$3.95 is a total ripoff for a .05 part, shipping I'm sure will more than double the price.
« Last Edit: May 01, 2015, 04:48:46 PM by Powderman »
Offline Gman
« Reply #13 on: May 01, 2015, 06:38:25 PM »
But the numbers molded in make it worth the $4.   :P
G
'76 CB550K
Offline Powderman
« Reply #14 on: May 01, 2015, 10:11:27 PM »
If the one CBDee bought was just a piece of cut tubing for $4, then who got took?
Offline CBDee
« Reply #15 on: May 02, 2015, 08:44:02 AM »
++I'd have to agree with that. which is why I urge people not to buy one but to just use a vacuum hose!  :)
Offline Powderman
« Reply #16 on: May 02, 2015, 01:59:47 PM »
Peace
Offline mgzych
  • '75 CB550F
« Reply #17 on: May 02, 2015, 04:22:29 PM »
The local auto parts store is sitting on a gold mine and they don't even know it!  They're handing out this stuff like fireman throwing candy at an Independence Day parade!  I should start a cottage business for brake lever bushings.  If the small stuff goes for $8/inch, imagine what the big stuff will go for!!!
« Last Edit: May 02, 2015, 04:25:47 PM by mgzych »
Offline Johnie
« Reply #18 on: May 02, 2015, 08:31:50 PM »
That hose is the same as the carb overflow tubing. I have used a piece of that and you never know it is missing  :)
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
