Author Topic: CB550 stalls while coasting  (Read 10055 times)
Re: CB550 stalls while coasting
« Reply #25 on: May 03, 2015, 08:41:47 PM »
#4 looks great, the others are super lean.
« Reply #26 on: May 05, 2015, 02:19:26 PM »
There's a caveat here for plug 'color', if you are running Conoco-Philips or Shell gasoline: these have, in most of the USA, nitrogen detergent aboard. This cleans the plugs a lot more than most fuel, so the readings come out much lighter than expected when the engine is set up right. Lately, this has thrown a lot of confusion into the "tuning" efforts of many SOHC4 riders.
One example: the normal colors for my 750 plugs has been, for 36 years until nitrogen showed up in the gas, a medium-to-dark tan. With these fuels, they come out plain white. Switching to Sinclair or BP locally will produce the "old" colors again, but it washes back off when I go back to the Shell, making the plugs look largely unused at all.
« Last Edit: May 15, 2015, 08:03:58 PM by HondaMan »
Offline SamP
« Reply #27 on: May 13, 2015, 08:30:57 AM »
Just wanted to update - sat on all this for a while until life slowed down enough for me to give it another go.
I figured with the jets smaller than recommended for my set up, I opened the mixture screws to 2 full turns out to enrichen the mixture a bit, and after discovering how to properly use my syncpro ("So that's what those little brass things are for..."), I synced again and got a whole new baseline for the carbs. Idles smoothly at just under 1000 and while it still sounds a little starved at 1/4 throttle (not sure how to describe what it does, but it sounds like the engine is stuttering - loping? Bogging down?), I'm gonna see how the plugs look after riding for a few days. If they look lean, I'll bump the idles to 45s and test again.
As it is she runs decent, idle doesn't hang or drop or stall out like before, so I know I'm headed in the right direction.
Thanks everyone. Will hopefully update again with more good news.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #28 on: May 13, 2015, 08:58:35 AM »
Did you ever mention where you needle clip position was? I think if you changed from 4 X 4 exhaust to 4 in 1 you might only need to change that. Try it one position at a time. I would try and raise the clip position which will lower your needle. That is based on theory for leaning out the mix for the change in exhaust. But your plugs already show lean so maybe try enrichening the mix by lowering the needle position? Remember every time you remove the slides or mess with them you will have to do a vac sync. That will be good practice. :) Also while you have the needle out you can clean it as well.
I'm not too familiar with the PD carbs but I know that's the basic difference between the older 550 K and F models is just clip position. It doesn't cost anything but time to try it and see. Good luck.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline SamP
« Reply #29 on: May 13, 2015, 11:51:39 AM »
I forget which notch the clip is on for the needles, but I do recall moving it down one notch from wherever it was, which would have lifted the needle (this was before I had any working concept of what this would do, I only thought "more gas = faster!"). I have a vague recollection of the clip being on the first, uppermost seat, so I'm pretty sure it's one below that, which should enrichen the mixture (unless I've got it wrong).
Thanks for the advice. I'll try that if swapping out for bigger idles don't resolve the issue at 1/4 throttle.
Offline cwchan
« Reply #30 on: May 14, 2015, 01:11:55 PM »
I have this exact problem too.  I think i need to adjust my float heights.  I couldn't find any actual instructions online or in the manual.
How do i go about this?
78 550 pd46c carbs too
Offline cwchan
« Reply #31 on: May 14, 2015, 03:09:45 PM »
Do you just bend the tang?
Offline DaveBarbier
« Reply #32 on: May 14, 2015, 03:29:09 PM »
First, I'd verify your float heights by the "clear tube method". Do a search in the forums of what's in quotes. No need to remove carbs or even take the bowls off just yet. Fuel level should be ~3-4mm from bowl seam.
As for adjusting floats, I was trying to find a step by step on the forum but couldn't find it. I know it's around here somewhere. Maybe someone else can post it.
1978 Honda CB550K
Offline SamP
« Reply #33 on: May 14, 2015, 06:11:14 PM »
It really depends on what changes you've made to your intake/exhaust, or jetting alterations, if any. From what I can surmise from my situation, my mixture was way too rich, and suddenly closing the slides from WOT had the effect of flooding the engine to a stall. Use the clear tube method to see what level your fuel is at, check your plug color and take it from there. And yes, you just bend the tang - it really doesn't take much to drastically alter the fuel level, so don't do anything too extreme in any direction. Be sure to hold both sides of the float while you adjust it, or you could torque it and it'll be uneven in the bowl.
Offline SamP
« Reply #34 on: May 14, 2015, 06:24:01 PM »
Now that I'm insured, registered, and inspected, I've spent the past two days riding around town. Can't turn the idle below 1000 or else it might dip too low and stall, but at 1100 there is a consistency to how she runs and I'm liking it.
I've come to discover that the 1/4 throttle issue really only ever happens when it's cold. Once the engine has warmed up, there is no hesitation anywhere on the tach. So I'm just going to chalk that up to the cold natured-ness of these bikes. Hopefully the transistorized ignition will help with that.
Now that I've synced those carbs up nicely, I decided to pull the plugs and take a look. #4 was carbon fouled all too hell, and I think that was due to an improper sync from user error early on, but I've replaced the plug in that cylinder and will check it again in a few days. The other 3 are posted below.
Cyl #1
Cyl #2
Cyl #3
I think they're looking pretty good, so changing jets doesn't look necessary. Fingers crossed that #4 looks identical in a few days' time.
« Reply #35 on: May 15, 2015, 08:10:57 PM »
With our ethanol-laced gas today, those are beautiful plugs!
If you're up for some more experimenting (I call it 'fine tuning'), consider this:
First, as a test, set the points plate back a few degrees so the timing is "late" an equal amount on both coils. Using low-octane gas, ride it a while a see if the hestitation goes away and stays away. If it does, the "fix it" step is to put the timing back where it belongs, AFTER you clip off 1/2 turn from at least one of the spark advancer springs (if not both), and re-bend that last loop to hook it back onto the advancer post.
The 500/550 Fours in particular tend to heat-anneal their spark advancer springs. This lets the timing then advance too soon. It should never reach full advance before 2500 RPM: most of the ones I see today are FAR sooner than that, and stumble until I "fix" them this way.
Offline SamP
« Reply #36 on: May 17, 2015, 04:16:15 PM »
Ethanol free at my local gas station.
Thanks for the advice on the test, hondaman. I might give it a go later this season when I've run out of things to tinker with  :P.
As is, she runs smooth when warm, and if it ain't broke...
Offline SamP
« Reply #37 on: May 20, 2015, 01:14:08 PM »
Well, as is the case, not so good news. Plug on #4 was fouled all to hell again, even after a good sync. Pretty bummed. Plug looks dry, so I don't think it's oil, but I'm not gonna rule that out. Could it be oil?
Before I go digging deeper, I'm gonna be checking my valve clearances, possibly sync again just to see if it is as synced as I think it should be. I'll be checking for vacuum leaks as well (only on #4 though).
On a suspicion a few weeks back I pulled off the cam shaft end cap covers just because...the one on the #1 side oozed oil as soon as I pulled it out, however the side on #4 did NOT do this. Under the tappet covers I can tell the whole cam is pretty well lubed, as are the valve springs. Could it be an oil leak from the channel on that side? Should I check the torque on the head cover bolts around #4? Really pretty lost here.
Lastly, there is a chance, albeit a small one, that I installed an oil ring upside down. The last time I broke down the top end, I had a hell of a time trying to find the word "top" on the damn ring, and being a noob, I hadn't marked it (don't ask why I took the damn rings off in the first place, I don't have an answer for that). I am 90% sure I saw the end of the letter "P" on the corner of the ring, but it's entirely possible I got it backwards.
Obviously breaking down the top end is not something I want to embark upon just yet (a last resort, really), so give me what you got.
Offline SamP
« Reply #38 on: May 23, 2015, 12:52:51 PM »
So after a bit of deliberation and rumination, I've convinced myself it's not an oil leak (deposits are dry and fluffy), so top end tear down probably won't do anything. I decided to check my spark advance that was WAY OFF (didn't fully understand how to set that before, but I researched it and got the timing set with an old turn signal.) Bit of an issue, I had set the point gap long ago but double checked it and it was good. Tried to set timing and got 1-4 timed right, but it was at the end of the free play in the plate, so then I couldn't set 2-3 correctly. Reset the point gap at .016 (up from .013), and was able to set advance on 1-4 and 2-3. Went for a ride, got back, checked again and it was off (!!!). set it AGAIN and this time it's stayed put.
Since I've corrected the timing, I've been noticing quite a bit of spitting back through the carbs, pretty consistently when warming up. This leads me to think my mixture is a bit on the lean side, and that I should try upping my slow jets (mixture screws are turned out to the point where they stop changing anything: 2 1/2 turns out, I believe?). But I don't wanna mess with that until I've got my #4 plug consistent with the rest, which all look great.
So, back to the point at hand. I checked the valve clearance on #4, and the intake valve was at .0025, so I closed it down a bit to be within spec. Between that and the spark advance correction, this has not addressed the carbon fouling.
Which leads me to think it's A) weak spark from coil, B) problem with idle, main, needle, emulsion tube, or mixture screw on #4, C) clogged passage within the idle mixture circuit not letting air through, or D) an issue relating to minor corrosion in #4 wherein the emulsion tube sits lower in the float bowl because the tube cannot go any further into the carb body. I suppose I could add that the butterfly valve on the choke could be failing, however they are failing in the other direction - when I hold the choke closed while starting, they tend to flap open. Still starts no problem, but I know that they tend to stay open rather than closed.
Currently checking A by swapping 1-4 coil with 2-3. If #3 becomes carbon fouled, I'll assume the issue is with increased resistance in the wire from the coil to cylinder #4, reducing spark enough to carbon foul the plug. If not, I'll check B by swapping out one by one, all the components between 1 and 4 and see if that affects #1 plug. C will require pulling the carbs and dipping them to ensure all passages are clear, and for D i'll need to measure how far the jets/emulsion tubes sit from the main body in comparison to one another.
Any other insights from anyone else would be appreciated.
Edit - I also vacuum synced again, and they were all even at idle. Turning the throttle a bit and they seem to pull unevenly, but once I let off the throttle it balances right back out. Don't know if this is normal behavior or not.
« Last Edit: May 23, 2015, 12:59:42 PM by SamP »
Offline jonda500
« Reply #39 on: May 23, 2015, 05:17:52 PM »
Hi Sam, I don't think it's your coils- the coils fire once every revolution making a spark simultaniously in both 1 and 4 (or 2 and 3). The cylinders all recieve a spark when the piston nears the top regardless whether they are on compression or exhaust strokes. So I'd rule out the coils, although the issue still could possibly be #4s spark plug, cap or lead.
A starter clutch thread:
Offline SamP
« Reply #40 on: May 23, 2015, 06:35:51 PM »
Thanks for the input jonda. I was still concerned about the actual wire from the coils to #4, so I needed to test it. After the swap I went on a 15 minute trip around town and when I got back, had a look. Plug #3 was still nice and gray, so I've at least confirmed my wires are not the culprit. Plug caps are new and known good.
Put all the coils back where they belong and swapped out the emulsion tubes and mains between 1 and 4, so I'll take another little joyride tomorrow and have a look. Took the time to remove the mix screw blow canned air up into the seat for good measure. Also measured how far down the main jets went below the seam, and between 1 and 4 the difference is negligible.
Concerns to be addressed later is the spitting back through the carbs. Mostly happens when just barely rolling on the throttle when cold, or even just idling without throttle. Would that be too small idle jets or too low needle position? Air filter is freshly cleaned and oiled.
Offline SamP
« Reply #41 on: May 24, 2015, 05:13:21 PM »
Did you ever verify your fuel levels via the clear tube method? If so, post up pictures please-
I did, but did not take pictures once I got #3 and #4 corrected. The last photos I posted they were 1 or 2 mm too low, so I raised them in both until they matched the others, and when they did I didn't take a pic. Can verify again, but I think I may be cornering the issue...
I swapped the emulsion tube and jets between 1 and 4 and rode it today like normal. About halfway through the ride it starts acting up, stuttering like crazy. I make it home and check the plug on #1, and it's wet with gas, whereas before it was nice and gray.
Swapped the tube and jet with some extras I had laying around in #1 (unfortunately aftermarket, but we'll see how they run in the meantime). Wasn't thinking clearly and took her for a ride instead of syncing, and the same issue came up, but made it home with lots of throttle blips at red lights. Now #1 is clean, gray and dry, but #4 is still all sorts of carbon fouled (I had cleaned it off, so these were all new deposits). I realize that this could be because I didn't sync before I went for a ride, so I'll sync it and see where it's at. Before I went for that last ride I knew something was wrong - it would idle well at ~1200 for 3-5 seconds, then dip to ~800 for a second, then right back to ~1200. Not sure if that's just an indicator that it needed a sync, or if something else with the spark advancer, which I needed to calibrate AGAIN. Think I need to replace it.
Further down the rabbit hole we go...
What's the consensus on aftermarket emulsion tubes? Yes? No? I know where the forum stands on jets, but what about those tubes? I've got 3 more to swap out with the other carbs, but I don't know if it's a good idea or not.
Offline SamP
« Reply #42 on: May 24, 2015, 07:09:25 PM »
Do you have a quality brand ignition plate? I seem to believe I read you were out of adjustment, then it wouldn't hold, now it's off again? I've got a good quality stock unit if you need to swap yours off. Probably even an advancer if I look hard enough. Let me know- I'd rather see someone put them to use to solve a finicky bike than have them lying about in a parts bin.
Yeah, my timing has been all over the place. It was set incorrectly after the rebuild, but I was able to static time it with a turn signal, and got it lined up right for both 1-4 and 2-3. Each time I take it out for a spin it seems to go back out of correct timing again, despite being clamped down firmly. Gap looked good, as did contacts, and the plate looks brand new. Not sure of the make, but I'll look it up tomorrow after I sync. If you had a spare plate/advancer I'd love to have the opportunity to try all this with some known good parts. Might end up trying hondaman's spring clipping technique, and it'd be nice to have a backup if that goes to pot. Let me know what you want for em.
Offline SamP
« Reply #43 on: May 25, 2015, 05:24:11 PM »
Another day, another discovery.
Tried syncing the carbs after swapping the jets/emulsion tubes between 1 and 4. They weren't too far off, at least enough to account for the carbon fouling. So while I was in there I decide to check the needle heights on each carb and see where they stand. Turns out they're all on the center clip of the needle. Now I know.
When putting them back I realized I didn't know which direction the slide was supposed to face (one side has a little notch cut out, and what appears to be a hole for a screw but nothing goes into it. Also, one side (front or back) has an upward taper, while the rest is flat. Problem is, it seems to fit both ways, and I don't know if I had installed it backwards on one of the carbs. Checked online and from the microfiche it looks like the slot goes on the left side so I confirmed that all were properly aligned.
Get the slides back in and installed and decide to sync again, and it's way off between 1 and 4, which makes me think I did have one or both backwards. Got it properly synced, even though it was still doing this odd sputtering every few cycles.
That's when I notice the resistor cap is arcing across #1 to the head! It's only a few months old, so I have no idea why it'd be doing that. Tried twisting the other caps into contact with the head  and they didn't seem to spark or arc at all. When I twisted the cap away from the engine enough the arcing stopped, and the little stutter that kept happening every few cycles stopped as well. Removed the caps and realized saw a lot of green corrosion in the lead. So essentially the engine is stuttering because the cap on #1 is arcing, and I don't know why it would do that. New coils or clip them and install new wires? Any help?
Other discovery - Hondaman, you are correct that my springs are annealed. I was reading through another thread where you and I believe dave were mentioning how the response just off of idle would be horrible when timed to the F mark, which is what happens to me. Really soft and sluggish in the low end in first, CONSTANT spitting back into the carb body. I tried advancing the spark a few degrees and it completely eliminated the spitting and horrible response when cracking the throttle. I know that's gonna affect the timing, but not sure how it will affect the syncing.
« Reply #44 on: May 26, 2015, 01:03:54 AM »
As a matter of fact this is a very common and known problem with the 500/550s. I cannot stress enough to always start with the simplest and check if maybe one of the caps is arcing. Best seen in the dark. Very easy and cheap to fix and NO need to go right at all kind of complex activities inside the carbs. BTW I'm always amazed how much talk there is in this forum (compared to others) about needle positions, float heights, syncing etc. It just doesn't match with what I've seen in over 35 years and I suspect a lot of echoing. Always start with checking the ignition including the points and doublecheck! It can save you lot of nasty work.
Offline SamP
« Reply #45 on: May 26, 2015, 03:02:48 PM »
I understand your frustration - I'm right there with you and have been through this seemingly unending process. But the issue started with stalling during coasting, which really was a carb issue - it's just recently transformed into this current manifestation. And all this input has been very helpful for me, and hopefully for anyone else who finds this thread years later that has been having similar issues. For example, now I know my spark advancer needs tweaking to be optimal.
I'll probably get an answer when I try running it again with new plugs, but my question now is would the arcing at #1 draw enough current to weaken the spark in #4 to cause plug fouling? Because if it doesn't, I've still got to solve that issue.
Offline SamP
« Reply #46 on: May 28, 2015, 05:08:15 PM »
Spark plug wire splicer + some fresh, new 7mm wires cured the arcing off the resistor cap. Installed a new plug in #4, synced, then went for a ride. Took out the plug and it's still fouled.
Which now means I think I've isolated it to a blocked passage in the idle circuit, since all the other plugs look fine, wires/coils don't change anything between plugs, needles and main/idle jets don't change anything. Float height is good and even across all 4. No vacuum leaks found, valves all adjusted to spec, compression good across all 4.
Any recommendations on a good dip? There seems to be contrary opinions on its efficacy, but I don't know if I can get the passages I need to get cleaned with wire alone (I'm not even sure I know where all these different internal passages lead, anyway). Otherwise not sure how I can know that all the passages are free and clear without replacing the body.
Any input on cleaning, as well as any other possible plug fouling causes I may have missed, would be appreciated.
Offline Tews19
  • I am no
« Reply #47 on: May 28, 2015, 07:08:41 PM »
I use the GUNK. it comes in a gallon paint can. Works great. cleaned at least 4 sets of carbs in the same can.
1970 Honda CB750 survivor.
« Reply #48 on: May 29, 2015, 12:34:47 PM »
Ultrasonic, if you have access to one.
Offline ANDY W
« Reply #49 on: May 30, 2015, 12:51:47 PM »
Didn't happen to remove the idle mixture screw out of #4 carb and check for a extra o-ring up in there?
