Author Topic: 1975 CB550 Carb overhaul / cleaning / rebuild  (Read 8638 times)
Re: 1975 CB550 Carb overhaul / cleaning / rebuild
« Reply #25 on: June 01, 2015, 11:24:40 AM »
Oooh yesss, that's fine for a nice idle but... you'll soon experience you have to turn back to a richer setting say 11/2 turn in order to have a good acceleration.
« Last Edit: June 01, 2015, 11:26:21 AM by Deltarider »
Offline eprovenzano
« Reply #26 on: June 02, 2015, 03:45:21 AM »
Thanks Deltarider I will keep that in mind. I attempted to vacuum sync last night... While not perfect it's much better...
Still a few thing to do before turning Louise back over to my son in law... I replaced the rear tire and tube, next is the front .  Also need to address a few small electrical gremlins.  We're getting closer to the finish line
« Last Edit: June 02, 2015, 05:20:37 AM by eprovenzano »
Offline eprovenzano
« Reply #27 on: June 03, 2015, 07:24:44 AM »
I was able to take a quick spin on Louise last night... Idles great, but falls on her face a bit in the upper RPM ranges.  I agree I may need to richen her up a bit...  I will adjust the fuel mixture screws and see what we get.
Offline Tews19
  • I am no
« Reply #28 on: June 03, 2015, 07:29:46 AM »
Everything stock?
1970 Honda CB750 survivor.
Offline eprovenzano
« Reply #29 on: June 03, 2015, 10:16:58 AM »
Yes stock, other then (I think) the needles.  When I cleaned the carbs, I noticed the clips on position one...  I don't have the needle number in front of me, but I don't believe they're stock.  With stock needles, this bike should have the clips on position 4... I would have expected the plugs to show a lean condition, but no... they were on the rich side.  I couldn't change the needle position as within two of the slides I was unable to remove the screws... so he clip is staying at position one.  ;D
On the stand, high revs are clean, bit it seems to run out of steam in the upper RPM's when under load.  It also has a slight backfire under deceleration. To me (I could be wrong) but that's a sign of a lean condition.  I'll take another crack at her tonight and see if I can't fine tune it a bit and clean her up some more.
« Reply #30 on: June 03, 2015, 10:31:50 AM »
When you're at the needles you may as well write down the stamped in (6 digits) number.
Offline Tews19
  • I am no
« Reply #31 on: June 03, 2015, 11:28:48 AM »
Cal is correct.
Offline eprovenzano
« Reply #32 on: June 03, 2015, 06:57:30 PM »
Well guys my son in law came up to collect Louise.  I had him take her around the block to make sure she warned up... The fuel / air mixture was at 2 1/4 turns.  We decided to start at 1 turn out and adjust from there...  At one turn, it would slightly backfire at idle... then we went to 1 1/4  turns out.  Better so I had him,take her for a ride ... Better but not quite there... It was getting closer so I went to 1 3/4 turns out.  I told him this time to go up a certain road where I know he can open it up and put the hammer down. He came back and said at 1st it shuttered and it was like she shook it off and then just roared. He said I don't know what you did but Louise has never run so well.  I took her for a little spin and yes she's running pretty good.
Update: I just talked to him this morning... He was planning on taking Louise to work... He said he flipped on the choke, and barely touched the start button and she roared to life...  Louise is a bit cold blooded, but after letting her warm up.. he headed of to work.   He said Louise is running like a fine Swiss watch... smooth.  I guess we stumbled onto the correct settings... but I'll take it...  8)  My Son-in-Law informed me when he came to pick her up, that 2 years ago on this date he bought Louise, and its the same date she's been reborn...
At this point I'm going to let him have some fun, and will check the plugs to make sure all is well.
I want to thank everyone for their help and support.   Louise is back, and better then ever ....
« Last Edit: June 04, 2015, 05:40:08 AM by eprovenzano »
