Author Topic: Quick Gasket Surface Question  (Read 942 times)
Offline Moffman
  • 1979 Honda CB650
« on: May 03, 2015, 03:25:16 PM »
Replacing the leaking headgasket on my '79 CB650, decided to pull the jugs and replace the base gasket while I was in there waiting on parts. What a royal pain in the ass. I've probably spent at least 8 hours just trying to remove the old gasket. I was using a razor blade, permatex gasket remover and a plastic scraper to not gouge anything.
The only time I've replaced a gasket on an aluminum surface was non critical areas like water pump gaskets and I would use stuff like rolloc discs to get a quick mirror shine. I don't want to use it here nor anything else abrasive like a scrotchbite pad and get grit inside the engine. I just spent another 3 hours razorblading the surface and I'm losing my damn mind.  The surface feels smooth but I still see what looks like old gasket material but the razor blade isn't really catching anything.
Which brings me to my question, am I over doing it here? I'd just like to avoid any leaks.
Thanks
Offline kmb69
Re: Quick Gasket Surface Question
« Reply #1 on: May 03, 2015, 03:44:01 PM »
The new gasket will seal much better if it is whistle clean. Looks pretty good in your pictures.
I always prep both sides of a new base gasket with a lite, even coat of Gasgacinch and let it dry before assembly just to be sure.
The Gasgacinch also makes life waaaay more better if you ever replace that gasket again.
« Reply #2 on: May 03, 2015, 07:18:47 PM »
Yes, removing gasket is a pain.
A clean garage towel and some acetone will show you where any remaining gasket is.  Acetone worked well for me.
I used a few light coats of copper gasket spray on my base gasket, and let it set up overnight.
No leaks...
Offline Moffman
  • 1979 Honda CB650
« Reply #3 on: May 04, 2015, 07:38:45 AM »
It seems like no matter how much I scrape their is still some left behind, I've got some gasgacinch actually, that's not a bad idea.
I've been using brake cleaner so far, I'll give acetone a try too.
Offline shinyribs
« Reply #4 on: May 04, 2015, 08:20:19 AM »
Lighter fluid works well to dissolve old gaskets. Not the stuff they sell for getting your charcoal burning, the fluid you would use in a flint lighter (zippo). Good luck.
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
