Author Topic: Handle Bar Bolt Torque Specs  (Read 1785 times)
Offline Jake1990
  • She's running....for now
« on: May 05, 2015, 07:11:58 AM »
How's it going guys and gals? I have a 1974 CB750 and I am replacing my old rusty handlebar bolts that clamp down my indicator panel. I couldn't find any specific torque specs online but they are 8mm bolts. Should I just follow the standard 8mm bolt torque spec or is there something specific that I am missing? Thank you in advance for any help and information!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Handle Bar Bolt Torque Specs
« Reply #1 on: May 05, 2015, 08:28:09 AM »
I went with standard for 8mm hex heads... 15 ft/lbs
http://www.salocal.com/sohc/tech/torquetable.htm
--Evan
1975 CB750K "Rhonda"
Offline Chachi
« Reply #2 on: May 05, 2015, 09:52:49 AM »
I just get all four seated and then tighten down the front two first and the bottom two after. Just good and tight. Not sure of torque spec. Never had an issue.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #3 on: May 05, 2015, 10:34:32 AM »
I don't think there is a particular torque spec for those bolts.  15 ft/lbs is a good general rule.
Offline 750K
« Reply #4 on: May 05, 2015, 11:31:44 AM »
+1 to this advice^^^
77 Cb750, 78 Kz1000
