Author Topic: new to forum — simple wiring question  (Read 919 times)
77kz
« on: May 05, 2015, 10:21:32 AM »
Hi all -
I finally picked up a 78 CB550 to tinker around on...happy to be a part of the community.
The previous owner thought it looked cool to ride around without any turn signals. Personally, I find it to be terrifying (among other adjectives), so I'm beginning with adding some rear signals.
I ordered a pair that each only have one wire (where the housing acts as the ground). I've located where the wires should be run and have them functioning properly in a testing position where I have a viable ground contact, but the area of the frame to which I'll actually be mounting them doesn't work as an adequate ground.
My (probably silly) question is this: can I splice the single wire and run an additional wire from it to a proper metal grounding elsewhere on the frame?
Thanks for your time.   :)
Offline Maurice
Re: new to forum — simple wiring question
« Reply #1 on: May 05, 2015, 10:29:24 AM »
You can run something like this:
See the hoop connector, that is the ground. The existing wire of course you can splice/make longer.
77kz
« Reply #2 on: May 05, 2015, 10:41:18 AM »
Thanks Maurice!
I thought about doing something like that, but I wasn't sure if that would work...
If the metal hoop connector (ground wire) was between the housing and a washer, then grounded to another part of the bike, would that suffice? I wouldn't be able to fasten the nut to the other side of the screw opposite the metal hoop because of fitment issues.
« Reply #3 on: May 05, 2015, 10:41:39 AM »
Of course you can.  Some bikes use a copper washer with soldered wire on it under the mounting stem nut.
77kz
« Reply #4 on: May 05, 2015, 10:52:17 AM »
Thanks 70CB750.
To be clear, is your advice is in response to my original question — that I can splice the one wire and add another that is grounded to another part of the frame?
…or are you saying that a ground wire with a metal hoop connector could be used between the housing and a washer?
Just want to be sure before I start cutting things.   ;)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: May 05, 2015, 12:13:09 PM »
Splicing the wire that gives the signal power will not turn it into a ground wire. Use the hoop method as mentioned above.
Offline Bodi
« Reply #6 on: May 06, 2015, 05:40:57 AM »
I, for one, am confused. I can't see how any part of the frame is  not grounded.
You need two connections minimum to power a light bulb: one is the wire and the other is the case on your units. Two wire types may have a dual filament bulb and still use the case, or have both single filament bulb connections wired out.
If the external wire bothers you you can remove the lens and have a look at the socket. Possibly it's easy to solder a ground wire to the barrel and thread it through the mounting stud. Running the ring terminal wire to a convenient ground point - any bolt going into the frame - is easiest.
Stock rear signal mounts are a metal bracket bolted or welded to the rear frame structure and handle the ground connection. The OEM metal rear mudguard is also a good ground.
