Author Topic: How much difference does three teeth make?  (Read 993 times)
Offline tennesseebreeze
  • Better to be lucky than smart.
« on: May 08, 2015, 06:54:50 AM »
I'm about to put a new chain on my 1973 cb500 build. I've got OEM front and rear sprockets- 17 and 34 teeth, respectively. I'm thinking about getting a rear sprocket with a few more teeth for a little more quickness off the line and in the corners. I'm looking at a 37 tooth steel sprocket. I could probably work out mathematically what I would gain from this. But I'm wondering what it FEELS like, should I go with even more teeth than that?
Wondering what other members prefer.
'79 CB750F, '73 CB500K2, '78 CB400A, '71 CL100
Offline eigenvector
Re: How much difference does three teeth make?
« Reply #1 on: May 08, 2015, 07:57:14 AM »
The front sprocket is where you'll feel the difference more than the back.
I remember when I changed out my KLR650's front for a highway gear - the bike was noticeably slower.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: May 08, 2015, 07:59:11 AM »
Ozarks or Cascades? Depends on which side of the mountains you're on.  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #3 on: May 08, 2015, 08:01:28 AM »
Appalachia. ;D
« Reply #4 on: May 08, 2015, 08:04:37 AM »
Selfie.
« Reply #5 on: May 08, 2015, 09:24:44 AM »
It might be too slow and weak.
I do not know CB550, but CB750 does not need smaller rear sprocket. 1 toth smaller front sprocket 17 instead of 18 for better city driving and better at top too when it will have more power. I remember that some guys used 45 rear instead of 48. Top speed will not be reached. Never for speeding people.
Here is the gear ratio for a CB750. Change the sprocket and see how it will affect rpm and top speed. Maybe it will gve an idea.
« Last Edit: May 08, 2015, 09:34:12 AM by PeWe »
Offline CBDee
« Reply #6 on: May 08, 2015, 09:30:44 AM »
Reducing size of front sprocket is not recommended due to the increased angle that the chain must follow, affecting chain life. Most of the experts say increase the rear sprocket if you want to change the sprocket ratio's.
« Last Edit: May 08, 2015, 09:42:58 PM by CBDee »
Sent from my Old & Busted PC using Myindexfingers
« Reply #7 on: May 08, 2015, 09:44:21 AM »
+3  on the rear is about the same as -1 on the front. I don't have a 500 anymore but I'd think it will like the change, they are made to rpm.  Is 17/34 really the stock ratio?
« Reply #8 on: May 08, 2015, 09:50:02 AM »
It's 17/34 for the 500's and 17/37 for the 550's of the era. I'm seeing 34's, 36's, 37's, and one 48 on Ebay. 48 must be for poppin' wheelies. :o
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: May 08, 2015, 01:11:32 PM »
I'm sure you could buy a 37T from a 550 used for cheap and test out and see if you like it, they should bolt up. If it's too much change then either stay with a 34 or try a 36.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline knottedknickers
« Reply #10 on: May 09, 2015, 03:31:46 PM »
You could go by the seat of your pants... Or you could use a calculator: http://www.gearingcommander.com/, http://www.sprocketcalculator.com/.
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
« Reply #11 on: May 10, 2015, 01:14:20 AM »
I saw more info about CB550: http://forums.sohc4.net/index.php?topic=89343.0
From Action Fours below
« Reply #12 on: May 11, 2015, 10:26:57 AM »
Went with the 17/36 in the end. It's a little bump up from the stock amount. This was some helpful information. Thanks all.
