Author Topic: CB550 headlight issue  (Read 918 times)
Offline jayowen
« on: May 08, 2015, 10:24:22 AM »
Headlight and taillight fuse is not getting any power. Already replaced right side switch. Any help would be awesome
DH
Re: CB550 headlight issue
« Reply #1 on: May 08, 2015, 10:40:15 AM »
What model? K1, K2..?....
year?
Offline ironrod60
« Reply #2 on: May 08, 2015, 10:43:04 AM »
To be honest, I know squat about electrical, but in the "Download Motorcycle Manuals" there is an electrical color code chart and an electrical systems service manual.
DH
« Reply #3 on: May 08, 2015, 10:47:53 AM »
   Jowen---Try turning the keyswitch on and turn the headlight on, then check for voltage at and through each fuse.
Those fuses are supplied current through the headlight switch and the ignition switch. Is your bike equipped so that the lights come on automatically with the key on? (headlite always on?) They work differently.
« Last Edit: May 08, 2015, 10:50:20 AM by DH »
Offline jayowen
« Reply #4 on: May 08, 2015, 11:06:34 AM »
It's a 1976 cb550f lights always on. We aren't getting power to the fuse for headlight or taillight.
DH
« Reply #5 on: May 08, 2015, 11:12:17 AM »
http://manuals.sohc4.net/cb500/service_manual/HSM500550_14.pdf
see if this helps you.....scroll to the end.
I am only familiar with the earlier k models, stepping aside for someone who knows more.
« Last Edit: May 08, 2015, 11:17:05 AM by DH »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: May 08, 2015, 12:12:57 PM »
How many fuses does your bike have? On the later models the headlight and tail use 2 seperate ones. Which would narrow the fault finding down if both circuits are affected.
Offline jayowen
« Reply #7 on: May 08, 2015, 12:21:58 PM »
There are separate fuses for tail and head lights. Both aren't getting power
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: May 08, 2015, 01:08:15 PM »
Ignition switch? try the park light position and see if you get anything.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline jayowen
« Reply #9 on: May 08, 2015, 01:50:47 PM »
Works in park. So ignition switch it is
Offline jayowen
« Reply #10 on: May 11, 2015, 10:54:22 AM »
New ignition and still doesn't work in run. Lights all work in park position. Anyone know where to look next?
