Author Topic: Carb cleaner as starting fluid?  (Read 5247 times)
Offline tommychains
« on: May 12, 2015, 06:57:49 AM »
Hi guys, did a search on this and I saw intermittent mentions of using carb cleaner to help start an engine that's been sitting around for a while. I have changed spark plugs, charged battery, and changed oil, and still having trouble getting the bike started. So I would like to try with carb cleaner. Is this effective? I assume just spray into the air pods? I have not yet checked the carbs though which may be the culprit.
Re: Carb cleaner as starting fluid?
« Reply #1 on: May 12, 2015, 07:10:44 AM »
Hmm, better rebuild carburetors, even if it starts now, if the carbs are clogged, it will not run well.
Offline Maurice
« Reply #2 on: May 12, 2015, 07:16:47 AM »
Never needed this. If carbs are clean, there's compression and ignition is adjusted the engine will fire no matter how long it's been sitting. I've restarted old engines in the winter without the electric leg and never needed any starting fluid.
« Reply #3 on: May 12, 2015, 07:24:10 AM »
Electric leg - I like it ;D
Offline lrutt
« Reply #4 on: May 12, 2015, 08:19:04 AM »
Yup, I've done that before.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3qptuua3kvhpi0058t7m9kolf1&/topic,60973.0.html
« Reply #5 on: May 12, 2015, 08:25:46 AM »
normal start fluid have some oil in it to lube the engine.
.kleaner dont have.
.the both can blov head gasket and hurt the engine.
.ekstra care this stuff are hard to dose and air mix is imposibel to get right..
i hate all this v-w.... vords
Offline tommychains
« Reply #6 on: May 12, 2015, 10:02:43 AM »
Thanks all I will not attempt this but will clean carbs first.
