Author Topic: Logan's Reward - CB500 and CB550 Cafe Projects  (Read 90168 times)
Offline Restoration Fan
  • My wife will never call me
« on: May 13, 2015, 07:48:03 PM »
Many of you know that my youngest son, Logan, restored a 78 CB750K for his senior project in high school and I decided to keep that bike as my own bike to ride.  Well, now the time has come to repay the favor and build a bike for him...that he wants to ride.
We found out that he is interested in the cafe styled bike and he doesn't feel comfortable learning to ride on a 750...so we started looking for something smaller.
Thanks to Bill Benton, we bought 2 frames, one set of carbs, a front rim, and a gas tank:
The first is a 1973 CB500 with a motor that won't turn over.
The second is a 1974 CB550F that's just the frame.
And thanks to Justin (aka justfours on this forum), we bought a complete but disassembled 550 and a complete and put together 500 engine that has compression and turns over.  Also, we got several rims (one is a 350, one is a 450, haven't checked the other 2 or 3 yet), plus about 4 boxes of parts.  Along with these parts are an extra set of cylinders, an extra head, an extra valve cover so I think we might be able to get the 500 engine that's in the 500 frame currently fixed in the long term as well.
Anyway, here's the plan:  remove the stuck 500 engine and replace it with the 500 engine that's running, get it running and learn how to do the lowered handlebars, a cafe seat and hide the wiring and battery.  This one won't have knee dents in the tank or rear sets to start off with.  It's the one that Logan will learn to ride on after he finishes his MSF class.  After he's comfortable with it, we'll put rearsets on it and let him get a bit of time riding that.  But this 500 bike will eventually be sold.  The money from that bike will be used to put the 550 back to life and that one will be tricked out like Logan wants it.
The eventual goal for Logan's bike will be something that we hope to have look something like this one...which is one of the bikes that I believe Devin from CognitoMoto did:
Re: Logan's Reward - CB500 and CB550 Cafe Projects
« Reply #1 on: May 13, 2015, 07:53:33 PM »
Do you think you'll do the inverted forks too, Ron?
cal, I love the look but I think the inverted forks are above my skill level.  On the first one, we probably will go with the single front disk as well but on Logan's bike, we'll do the dual front disk.
« Reply #2 on: May 13, 2015, 07:57:11 PM »
Sounds like a good plan, I'm in.  I think you'll like the 500/550's they are fun little bikes to ride.  And perfect for him to learn on.
« Reply #3 on: May 13, 2015, 07:57:34 PM »
I drove to Palatka, Florida all day on Monday to pick up the engines and parts and then we went over to Bill's today and got the frames and other stuff.  We haven't even had time yet to do a full inventory or sort and/or organize.
« Last Edit: May 13, 2015, 08:03:06 PM by Restoration Fan »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #4 on: May 13, 2015, 08:02:20 PM »
Nice, I do have a complete CBR1000RR 2008 inverted front end! ;D Bill
BentON Racing Website
BentON Racing Facebook
« Reply #5 on: May 13, 2015, 08:04:48 PM »
Oooh....ok hold onto that one for me.  When we get around to doing Logan's bike, we might want to do that.  I think the look is really cool.  Especially if you have the front rim with the cool looking double rotors?
Have a safe trip, Bill.  Thanks again for taking the time out today to help me locate parts and stuff when you're getting ready to go on your coast-to-coast swing.
« Last Edit: May 13, 2015, 08:30:00 PM by Restoration Fan »
Offline danyo
« Reply #6 on: May 13, 2015, 08:40:42 PM »
Subscribed :)
Offline rb550four
« Reply #7 on: May 13, 2015, 08:46:54 PM »
My , that's quite a pile of parts, a good start.
« Reply #8 on: May 14, 2015, 07:57:25 AM »
I agree. The modern fork swap is easy. You can take the money you'd spend on rebuilding the original forks and use it toward your fork swap. The modern stem may not need to be sapped since the front is a 550 (vs a 750).
Offline mkoski
« Reply #9 on: May 14, 2015, 08:25:38 AM »
Yeah, I wouldnt be concerned about the skill required! I am just finishing up my 750 and am now doing a 550 as well and I am looking to do a GSXR swap (inverted fork, swingarm) so I can skip the hassle of rebuilding the wheels, forks,ect. I think it will actually be more easily done and more quickly!
Its funny you posted that up, that bike is exactly what I want to do too! Good taste!
Offline Maurice
« Reply #10 on: May 14, 2015, 08:36:07 AM »
Subscribed :)
« Reply #11 on: May 14, 2015, 08:47:02 AM »
It's a good thing that there's no shortage of modern forks/front ends!
Offline Maurice
« Reply #12 on: May 14, 2015, 08:49:03 AM »
Problem is a lot of them are bent :D
Offline Justin
    • Cj's Garage
« Reply #13 on: May 14, 2015, 11:28:44 AM »
Ron - inverted forks are easy, actually. Devin @CognitoMoto makes it even easier. He sells steering stems to swap the new front end into the stock 550 neck, plus, he sells his front hub that is perfectly set up to lace a rim (17",18" or 19") to the front end and you use the donor rotors and calipers. Leave the rear wheel as is (stock hub) and away you go.
If Bill have the CBR front end, calipers and rotors, just contact Devin for the hub and stem.
http://cognitomoto.com/collections/fork-conversion-parts/products/cbr1000rr-2004-2012-hub-bolt-on-conversion-laced-wheel
http://cognitomoto.com/collections/fork-conversion-parts/products/cbr600rr-cbr1000rr-fork-on-honda-cb750-frame-conversion-stem
http://cognitomoto.com/collections/cognito-moto-originals/products/triple-clamp-with-monoscope-mini
That last link is a custom top clamp spaced for the CBR front end, with an integrated MotoGadget multifunction gauge and instrument lights (LED). OF course, you should also install a steering damper (and thats usually found stock on the CBR). (Call me, I'll drive down and we'll wire you up in no time.)
Easy as can be. Then Logan will have a "custom" bike, upgraded handling, braking, and fit his preferred style. The gauge is electronic, so you can abandon the stock speedo drive gear and stock mechacnial tach. Clip-ons are best suited for this application.
What else do you need? Rearsets? He's got them. Seat? Widely available. This bike should take less than a week to build now that you've got your list and suppliers.
What a wealth of information, Cal. For my .02, I think it'd be worth it to do the inverted fork front end, given that it's roughly plug and play.
« Reply #14 on: May 14, 2015, 12:13:24 PM »
For some members, they want to keep the bike true to stock or period correct.  Since Logan likes the aesthetic of Devin/Cognitomoto's 550 -- which uses a modern GSXR front -- it would make sense to take advantage of both a braking and handling improvement for his safety and allows some additional modern rubber choices depending on wheels used.  Provided an affordable donor front end (and it looks like Bill has one at the ready), it will save some time in rebuilding the stock 40 year old front, too.
Offline AintNoEasyWay
« Reply #15 on: May 14, 2015, 01:37:50 PM »
Awesome. I'm in for another ride!
« Reply #16 on: May 15, 2015, 05:22:37 AM »
Any of you guys have a good recommendation for a small, good quality battery that would be easy to hide away on a cafe styled bike?  I want to go ahead and buy one to test some of the electrical components (starter, solenoid, etc) on the new 500 motor before I put it into the 500 frame.  I got the old one out last night and removed some usable pieces like the tach assembly etc but I want to test the oil pump and confirm it's getting good pressure before I put it into the frame.
I'm guessing that I'll end up going with a Lithium Ion battery from some manufacturer but I would prefer to get recommendations from people like you guys who have done this before before I go purchase one.  The Scorpion which was recommended for Stella has been very good but I'm looking for something smaller for these bikes.
Offline knottedknickers
« Reply #17 on: May 15, 2015, 05:25:24 AM »
Looks like someone got bit by the bug--HARD! ;D Go for it, guys!
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
Offline Maurice
« Reply #18 on: May 15, 2015, 05:39:17 AM »
Ron I would not go with Li-Ion or anything similar (LiFEPO4 etc). Those batteries are not very good at staying a long time unused, handling deep discharges or high charge rates (granted, the latter might never happen on the CBs :) ). They have a fairly narrow charge window, outside of which the battery is simply toast. Sure it's nice and light, but you need a computer, a very steady source of current and regular use.
I'm no EE but I've toyed with these a bit, built a couple high-candle LEDs for night MTB.
I saw something very interesting once, using super-capacitors. Now that is something to be excited about. They charge in seconds and hold that charge for a week or so, much lighter than a battery and last potentially forever.
At any rate, depending on whether Logan is ready to ditch the electric start you can go real small with dependable SLA batteries. And cheap.
Logan is lucky. When I was his age the best I had was a trashed moped that I rebuilt to go to school, a rare Solex with the engine at the bottom. If the engine failed you could always use the leg-powered crank :)
Offline martin_uk
  • CB750F1 CB750K8
« Reply #19 on: May 15, 2015, 05:57:14 AM »
Sounds like you are not wasting any time on the next project  :o, interested to see how it progresses
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline Maurice
« Reply #20 on: May 15, 2015, 06:36:02 AM »
Fair enough Cal, I bow to your experience. With proper equipment, care and quality material (and if money's no object) then go for it. I'm somewhat of a (okay, a complete) cheapskate and only use the battery tender that is on the bike :D
« Reply #21 on: May 15, 2015, 07:48:05 AM »
No offense, Maurice, but your statement about lithium-ion discharge is completely incorrect. Lithium-ion batteries can sit for a year and if you disconnect the negative terminal, they will suffer little to NO drain. The also seem to charge faster.
Offline Maurice
« Reply #22 on: May 15, 2015, 08:10:58 AM »
Maybe I'm not conveying what I mean. Read up here, disadvantages section. What I mean to say is that battery capacity will degrade over time, used or not. It may degrade faster in certain conditions too. And once it degrades there is no salvaging it. That is the physics of it, now in reality you may be able to keep using them at degraded capacity for quite some time since AH ratings on the CB are overkill.
I personally would not use those, I just see no need for it because most of my bikes are kick-only. And on the bikes that are not I use cheap AGMs that last for years, never use a battery tender.
Again, if money is no object and electric start a must then go for it, ignore my cheap-ass ramblings ;)
« Reply #23 on: May 15, 2015, 08:27:51 AM »
Hey, I appreciate the responses from each.  One of the great things about this forum is the exchange of ideas so thanks to each of you.
Cal, do you have a specific model # you recommend?  On Amazon, I'm seeing a bunch of different ones/sizes and I don't mind paying for the Shorai battery tender to go along with the battery.  On both of these, size is going to be an issue and I don't want to force the kid into kick start only at this point.  We may later decide to go that route but I'd like to have the starter available if he wants to go the electric start route.
Offline mkoski
« Reply #24 on: May 15, 2015, 08:41:11 AM »
I bet he will want kick-start.  :D I'm a younger guy and there's just something about a kick-only vintage bike. I think this is because our generation hasn't ever had to kick-start a single thing in our lives. Plus, a well tuned engine that kicks cold and first try is something to behold. AND removing the heavier battery, starter motor makes it faster...
