Author Topic: Logan's Reward - CB500 and CB550 Cafe Projects  (Read 76770 times)
Offline Restoration Fan
  • My wife will never call me
Re: Logan's Reward - CB500 and CB550 Cafe Projects
« Reply #225 on: September 30, 2015, 08:23:58 PM »
The PDM 60 finally came in today.  I only had a few minutes to work with it before I had to leave to go to the funeral home for a viewing for my wife's aunt.  I have to say that I am impressed with the quality of the product.
As it arrived in the package:
Items in the box:
Each wire and/or circuit is clearly labeled:
Test mounted in the box.  I have a rubber bushing that I'll be using and the wires will all be wrapped in heat resistant shrink wrapping for final installation:
I also got a call tonight that the wheels are ready so I'll stop by and pick those up on the way home from the funeral tomorrow afternoon.  The wheels will go on the bike and the wiring will commence.  Assuming that I don't hit any unforeseen events or problems, maybe I can get this thing running by the end of the weekend.
« Reply #226 on: October 01, 2015, 04:02:07 AM »
I have a rubber grommet or bushing for where it goes through.  I was just testing it yesterday to ensure that the hole I drilled was large enough to suit the purpose.
Great tip on the braided plastic sleeving.  Where do you buy yours, cal?
« Reply #227 on: October 01, 2015, 04:24:20 AM »
McMaster-Carr. I use 1/8", 1/4" and 3/16". I buy it on the spool in 25' lengths. Since your 500 is going to be somewhat stock, you may also want a 10' piece of 3/8" for the main harness section.
http://www.mcmaster.com/#standard-cable-sleeving/=z6chh1
I use the expandable and finish the end with a short piece of heat shrink to keep it put. Scissors to cut it.
I was going to ask you where you get it from, should have known McMaster has it  :)
« Reply #228 on: October 01, 2015, 05:15:18 AM »
I used to think full length heat shrink was better, but then I began examining how rigid it makes the wiring in the loom, how impossible it is to troubleshoot electrics, and found this stuff. I much prefer it. I leave enough wire color exposed at all junctions to assist with routing identification and troubleshooting.
Plethora options, which one are you using?
« Reply #229 on: October 01, 2015, 05:30:23 AM »
Aha, thanks!
« Reply #230 on: October 02, 2015, 04:03:11 PM »
I have a Honda ignition switch that came with this triple tree but it did not have a key with it.  I don't see any kind of number on the switch.  How does one find out where to get a key to replace the lost key?
Is it as simple as taking the ignition switch to a Honda dealer and trying multiple keys?
« Reply #231 on: October 02, 2015, 07:50:52 PM »
There should be a number on it, look underneath.
« Reply #232 on: October 03, 2015, 10:39:59 AM »
I found a number stamped on the side of the metal part of the lock with a format of 3BJB26.  That's the only one I see on it.
Can I give that number to a Honda dealer and get a key for it?
« Reply #233 on: October 03, 2015, 11:07:36 AM »
That's not a key number.  Should be like T4635....
http://www.ebay.com/itm/Honda-nos-orig-ignition-key-CB750-CB550-CB450-CB350-CB-750K-550K-350F-1968-76-/301756283306?hash=item46421379aa&vxp=mtr
Do you have a seat lock for that bike? Some seat locks have the number on it.
« Last Edit: October 03, 2015, 11:09:35 AM by Stev-o »
« Reply #234 on: October 03, 2015, 12:27:46 PM »
It didn't have a seat lock on this frame, no.  However, the triple tree came in the boxes-o-parts that I purchased in Florida and there were 2 seat locks in those boxes as well.  But there's no guarantee that the seat locks came from the same bike as the ignition switch.  I just went back over the switch with an LED light and a magnifier and I can't find any other codes written on it.  I suppose it's entirely possible that this isn't an OEM switch but it's pretty heavy duty so it leads me to believe it is.
I think I'm going to contact a locksmith and see if he is able to make me a key to fit it if I drop it off with him.
« Reply #235 on: October 03, 2015, 01:16:32 PM »
I have an extra switch with key, however there is no plug on the end of the wires.  May not matter if you are doing a custom wiring job.  Let me know if you want pics or PM your address and I'll ship it on Monday.
« Reply #236 on: October 03, 2015, 05:17:45 PM »
Stev-o,
I may take you up on that but let me see if I can get one from a Honda dealer or from Bill Benton that fits this one first.  If I can't match this one up, I'll shoot you a PM.  I truly appreciate the offer though.  Very kind of you.
Offline MickB
« Reply #237 on: October 05, 2015, 01:00:23 AM »
Resto you and Logan will have a lot of time together over the next few months. Lots of cleaning and restoring.
I started with boxes of parts like you two. Logan will learn heaps starting with a complete build.
Look forward to following the build.
« Reply #238 on: October 05, 2015, 06:39:38 PM »
Cal or other wiring experts,
Do you purchase your wire from McMaster-Carr as well?  If so, what size & how much do you recommend I purchase to be able to wire both bikes?
Looking at this old wiring harness, it appears there is some 12, some 14 and some 16 gauge wire in there.  Couldn't I just go ahead and purchase all 12 to save trouble?
« Last Edit: October 05, 2015, 07:06:43 PM by Restoration Fan »
« Reply #239 on: October 05, 2015, 07:57:44 PM »
Thanks, cal.  I just went in and placed my orders to get a couple of different types of kits from Vintage Connections, plus their crimping tool.  And now I have purchased 3 45 foot rolls of 18 (one in black, white and red).  I'll see if I can find some of the other colors and order those as well.
Now that I have the wheels back, I'm going to button those up once the new brake pads come in for the front & rear.  The PDM 60 is installed in the battery tray I purchased.  My buddy Mike has been making me a wiring diagram for the 500, using the circuit ideas I had for the PDM60.  He & I are supposed to go over that tomorrow at the office and make sure we have everything covered.  Once I have that, I'll post it out here for you guys to critique.
On a different note, I'm going over to Bill Benton's house on Saturday to watch as mark52 starts his beautifully restored 75 CB750K for the first time.  I had the pleasure of helping him with the engine rebuild and the wiring, as has Bill.  So it should be a fun time.  What would be REALLY nice would be if I had the 500 ready to start as well but I don't think it will be ready quite that quickly.
« Reply #240 on: October 07, 2015, 09:20:03 AM »
I ordered a set of left and right controls from eBay that I knew were going to be pretty cheap controls (I think I only paid about $15 for both controls shipped).  When I received them, I was surprised that they were a bit sturdier than I expected but on the down side, there was absolutely zero documentation with them.
My buddy Mike and I went through the wiring diagram yesterday and I have to say that he has done a marvelous job with it.  To finish it up though, we needed to know the wires for these controls and which wires were for which control.  So I sat down last night with my multi-meter and sorted out which wires go where.  I have read a lot of threads with people questioning their wiring for the their controls and how to wire them up so I thought I'd post a quick update on how I figured out my wires for these controls, in the hopes that it might help someone else out at some point in the future.  One caveat is that I'm no wiring expert so please forgive my ignorance if I say something that sounds stupid.
First things first is that I want to check for continuity on the wires to determine which wires make a continuous connection whenever a certain button is pushed or is in a certain position.  To do this, your multimeter has a setting that will make an audible tone when you have continuity across 2 wires.  On mine, the symbol looks like a little speaker with waves coming out of it.  If you're not sure if you have yours on the correct setting, place it in the one you think is right and then touch the two probes together....you should hear an audible tone as long as they are touching and the tone should stop when the connection is broken.
Next, here are the controls I'm working with:
Ride Side Controls
Left Side Controls
So to begin, these controls are similar to the way that OEM Honda controls connect to the handlebars.  They have 2 pieces that separate to allow you to put it onto the handlebars and then they're connected via screws that go through one side into the other.  Well, we can use this to get a glimpse into the controls and see which wires go to which control switches.  I wasn't able to see all of the wires and I didn't want to take the switch apart (which would be the simplest way to determine the wiring, by the way).  But I didn't want to do that because these are cheap controls and I didn't want to do potential damage by taking them apart.  But I can look at those wires and that gives me a hint as to which wires I should test for the different control switches.
Anyway, to begin, take a piece of paper and use it to make notes of your findings.  Place the multimeter into the appropriate setting and begin by touching the black probe to one wire and then move it to touch each & every wire until you hear a tone or not.  Continue this until you've gone through all of the possible permutations.  Then, move the control switch you're testing to the next position and repeat these steps, writing down your findings each time.
Here's what I found regarding my controls:
Left Side Controls
Top Switch - (High & Low Beam Switch)
Low beam (bottom position) - Dark Blue/White & Dark Blue wires
High beam (top position) - Dark Blue/White and White wires
Middle Switch  (Turn Signals)
Left Turn - Orange & Gray wires
Right Turn - Gray and Light Blue wires
Middle Position - no continuity
Bottom Switch (Horn button)
Dark Green and Light Green wires
Right Side Controls
Top Switch (not sure what this is for; I'm assuming it is for turning on/off the headlight with a 3rd position for just having the running lights on when parked...I don't know what their real purpose is but this is how I'm going to use it)
Bottom position - Brown/White, Black and Brown wires (I'm going to use this for just the running lights being on...for use when parked on side of the road, etc)
Middle position - No continuity (I'm going to use this to enable turning the headlight and running lights off)
Top position - Blue/White, Black and Brown wires (I'll use this for headlight and running lights all on)
Middle Switch (Engine run (ie kill) switch)
Off position (left) - no continuity
On position (triangle on right) - Gray, Light Blue and Orange wires
Bottom Switch (Starter button)
Black and Yellow/Red wires
Anyway, I hope this simplistic explanation helps someone.  I just sent an email to Mike with the details and I'm hoping to post the wiring diagram either today or tomorrow.  I received notice from McMaster-Carr and Vintage Connections that my packages have shipped, so I should be putting this to use on the bike soon.
« Last Edit: October 07, 2015, 09:21:59 AM by Restoration Fan »
« Reply #241 on: October 07, 2015, 10:10:08 AM »
Thanks for documenting them. Care to share the seller's name on eBay and how they described them in the title?  A link to their current listing of what is for sale  will be good for longer than a link to another item like you purchased, fwiw. Thanks! David
p.s. interesting that they used the same wire colors in some cases.
« Reply #242 on: October 07, 2015, 11:23:31 AM »
Ron,
Thanks for sharing the knowledge.
For the future, you may want to pay a little extra (next time) and try the K&S Technologies switches.  Great quality and good prices (from various ebay vendors).  Just select the model you like and then run a search in ebay for it.
http://www.kandstech.com/index.php?page=switchescontrols
I use the Left-Side 12-0030 (it has a light OFF position and a high-beam flash) and the Right-Side 12-0030.  Zero issues.
« Reply #243 on: October 07, 2015, 01:02:53 PM »
OK, my bad.  I actually ordered them from Amazon.
http://www.amazon.com/gp/product/B00TX5SAU0?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s01
Don,
Thank you, I didn't know about those.  But for this flip, I'm actually fine with the quality of these.  They're a bit sturdier than I expected and the switches have a decent quality feel to them.  For $15.83 for the pair shipped, I'm fine with using these.  And in the comments, I had already read someone say that they come without wiring instructions.  But I reasoned that I could probably figure out which wires were involved for each switch and was fine with that.  Thanks again for the link though.  I'll definitely keep that one around.
Offline GizmoDuck
« Reply #244 on: October 07, 2015, 04:19:25 PM »
Got those same controls too and they are fairly solid.  They had several buttons that were not needed for my bike so I combined all the switches except for kill and start on the left switch and am using the factory Honda switch on the right.
« Reply #245 on: October 08, 2015, 04:03:48 PM »
We finally finished the wiring diagram for the 500.  I'm super pleased with the job that Mike did on it.
We spoke with the people from Rowe Electronics a couple of different times.  They're a small company and they actually welcome customer service calls....their people were incredibly friendly and helpful.  Our primary question was whether or not we needed to put an external fuse between the key switch and the trigger wire for the PDM60 because we didn't want to take a chance on blowing out the PDM60.  Their engineer called me back quickly and we spoke briefly and he told me that we didn't need to worry about because that incoming connection on the Trigger wire is already internally electronically fused.
I have a little work to do on the rear turn signals on Stella tomorrow now that I have most of the mounting hardware but I'm hoping to be able to start the wiring process this weekend.
« Reply #246 on: October 08, 2015, 05:10:53 PM »
Cal,
Thanks for the input.  Mike chose those colors because I asked him to use the actual colors that were coming out of the PDM60, since it has those colored wires coming from the unit itself.  Each wire is about 12 inches long and we decided to carry those colors forward throughout each circuit.  Also, the colors that are coming out of the switches are the actual colors in those cheap switches I purchased.
So, for instance, if I'm looking at a yellow wire, I will know that it is only going to the headlight, the switches for the headlights and the tach/speedo lights.  I agree it's going to make it a bit more difficult with the 2 wires to determine if one is coming from the left or the right but since there will only be those 2 or 3 yellow wires in there, it'll be fairly easy to trace one of them to determine which is left or right.
Since I'm not using the standard wiring harness but instead running the wires myself, we figured we'd put together this diagram and I'll provide it electronically, as well as a paper version to whomever ends up purchasing this bike.
« Reply #247 on: October 14, 2015, 12:54:05 PM »
I was looking at the regulator/rectifier that I already have and then I also pulled up the photos online of the combination regulators/rectifiers.  Here's my question:
The wiring connection coming from this 72 CB500 stator has a 9-prong male connector, in which are 6 wires.
The wires are the colors specified in the wiring diagram for the 500:
But the regulator I have (and the Ric's Regulator/Rectifiers all have male plugs as well.
BUT I also notice that Ric doesn't make one for the 500, just for the 550.  At least on the www.motorcycle-superstore.com site, you can only select as early as a 74 and then only a 550 and not a 500.
Is it normal for the 550 to have male plugs coming from the alternator?  And if so, does anyone make a regulator/rectifier combination to fit it?
« Reply #248 on: October 14, 2015, 01:54:39 PM »
Ron - I typically cut the factory spades (male and female) off and crimp on new ones to fit the Ricks plug. This also allow me to split the NEU/OIL lines out of the plug and into smaller configurations. If this is for a "flip" bike, just use new crimps to mate to the Ricks and be done with it.
That's what I was thinking to do as well.  Thanks!
« Reply #249 on: October 14, 2015, 06:12:56 PM »
Aren't these also the connector blocks that often have melted connector bodies because of increased resistance/heat before total failure? They often need replacement,  so I would do as Cal suggested.
Also,  I see 7 , not 6 wires.
David
