Author Topic: Oil leak from crankshaft seal question (fixed I think)  (Read 861 times)
Offline Davez134
« on: May 25, 2015, 07:02:36 PM »
Noticed a slight oil leak from crank seal on my cb750. Have a question, not do much about replacing but hopefully fixing? Posted here on my project thread
http://forums.sohc4.net/index.php/topic,139768.msg1687683.html#msg1687683
Thanks for looking!
« Last Edit: May 26, 2015, 03:05:11 PM by Davez134 »
Offline Davez134
Re: Oil leak from crankshaft seal question
« Reply #1 on: May 26, 2015, 03:04:17 PM »
I think I fixed it by lightly tapping edge of seal so it sits square in its spot now. 30 mile ride and all dry so far. Fingers crossed that did the trick.
Offline edwardmorris
  • Youngish
Re: Oil leak from crankshaft seal question (fixed I think)
« Reply #2 on: May 26, 2015, 03:05:58 PM »
That's great! Be sure to add some permatex around the edge too. If it slips out of place again, I'd be worried about the crank twisting???
Offline Davez134
« Reply #3 on: May 26, 2015, 03:39:21 PM »
Crap, I didn't apply any sealant. What permatex would you use? all I have is hondabond.
  • Youngish
« Reply #4 on: May 26, 2015, 03:43:27 PM »
Their #2 non hardening one, easy to use and washes right out with acetone on disassembly.
I meant apply it on the outside of the rim as I assumed you didn't pull it out all the way and then drove it back in...
