Author Topic: Hoses!  (Read 2129 times)
Offline Timindecaturga
Hoses!
« on: May 16, 2015, 03:14:51 PM »
Ok I'm getting a new muffler so the bracket is gone  but these hoses are... Needed ? Can be cut shorter?
Not needed?
Suggestions welcome please
Re: Hoses!
« Reply #1 on: May 16, 2015, 03:24:29 PM »
 It's a 1978 750f SS
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Hoses!
« Reply #2 on: May 16, 2015, 03:27:09 PM »
Well, since we're having to guess at the year and model, I'm going to guess that the fuel tank has a door, and that we're dealing with a 77/78 K or any SS or A model. The clear tube is the fuel overflow from the fuel cap well under the door. Better to have it drain on the ground under the engine as opposed to it dumping down on to the top of a hot engine.
The black hose with the plug is from the water separator that is part of the PCV system and should have the plug pulled for the hose to drain as part of the regular tune-up procedures. It can be shorter, but I would retain it as long as the separator under the battery tray is in place. I imagine the foam filter media inside this separator has long since disintegrated, so you might want to inspect it. I use the green foam filter media that is used on lawnmower engines as a replacement, just cut to fit.
You elaborated before I finished!   ;)
« Last Edit: May 22, 2015, 04:37:40 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Hoses!
« Reply #3 on: May 22, 2015, 04:23:00 PM »
Ahhh I'm so small
So I just need a drain  from the tank
I missed that but yes new  hose
Thanks @madmtmotors
Re: Hoses!
« Reply #4 on: May 22, 2015, 04:23:33 PM »
Size on tubes or get clamps
Re: Hoses!
« Reply #5 on: May 22, 2015, 04:47:10 PM »
The overflow tube from the fuel tank is shown on the parts fiche as 9mm. 3/8" would probably work.
TAMTF...
Wilbur
Projects:
Offline oldhatt45
Re: Hoses!
« Reply #6 on: May 25, 2015, 06:09:54 PM »
Just found something interesting regarding the 3.5mm and 5.5mm hoses.
http://www.hondapartsnow.com/genuine/honda~bulk~tube~35x1m~95001-35001-60M.html
http://www.hondapartsnow.com/genuine/honda~bulk~hose~95001-55003-60M.html
It seems they use the same part number for the Honda CR-V.  LOL
Charlie
Offline edwardmorris
  • Youngish
Re: Hoses!
« Reply #7 on: May 25, 2015, 09:22:39 PM »
Those aren't specific to vehicles, I think they're standard Honda ones. Here's most of them
Honda OE Hoses
Fuel tube - 1 Metre long
Part number          - ID    - Color
95001-3500160M - 3.5mm - Black
95001-3500150M - 3.5mm - Black, braided exterior
95001-4500160M - 4.5mm - Black
95001-4500150M - 4.5mm - Black, braided exterior
95001-5500160M - 5.5mm - Black
95001-5500150M - 5.5mm - Black, braided exterior
95001-7500160M - 7.5mm - Black
95001-7500150M - 7.5mm - Black, braided exterior
Vacuum tube - 1 Metre long
95005-3500120M - 3.5mm - Grey
95005-4500120M - 4.5mm - Grey
95005-5000130M - 5.0mm - Black
95005-5500120M - 5.5mm - Grey
95005-7000150M - 7.0mm - Black
95005-7500120M - 7.5mm - Grey
95005-8000120M - 8.0mm - Grey
Offline oldhatt45
Re: Hoses!
« Reply #8 on: May 26, 2015, 05:02:48 AM »
Rafi,
Part of my point was the price of the CR-V hoses.  :)
The 3.5mm hose in particular.  :)  :)
Also, the tubing that comes out the bottom of the carbs (overflow I think).
I can't find the specs on that hose.  Do you know what size it is?  It does look like it's smaller than 3.5mm.
And Thanks for the part numbers!!!!  They have been entered into my notebook.  :)
Thanks,
Charlie
  • Youngish
Re: Hoses!
« Reply #9 on: May 26, 2015, 03:09:09 PM »
3.5mm is the right size or at least I believe it now, just installed it last night along with the wire clamps from Honda, very snug fit if you ask me.
Offline oldhatt45
Re: Hoses!
« Reply #10 on: May 26, 2015, 03:14:21 PM »
Rafi,
Very Cool!!!!!!  Thanks.
So why did you put new hoses on that new 750???????  :)  :)  :)
Charlie
  • Youngish
Re: Hoses!
« Reply #11 on: May 26, 2015, 03:21:49 PM »
Rafi,
Charlie
They were missing  ;D ;D ;D ;D
