Author Topic: high performance cam replacement options cb500k  (Read 627 times)
Offline Calisoul
« on: May 16, 2015, 06:53:17 PM »
So I was reading Hondaman's recommendations on getting more power for my 1973 cb500K2. I figure since I have the engine apart I should look at some higher performance options. Hondaman recommends installing a cam with longer duration (more overlap). Doesn't seem like a terribly expensive or complicated option so I'm looking into it.
Anyone have any recommendations?
He recommends the Yoshimura street cam but those aren't available anymore.
Thanks in advance
Re: high performance cam replacement options cb500k
« Reply #1 on: May 16, 2015, 07:01:57 PM »
Thanks in advance
Maybe think about a port job and valve polish: that helps a bunch, too! Don't go wild with the cam, because it is a small-bore engine: too much cam will quickly drown it.
Offline Calisoul
« Reply #2 on: May 16, 2015, 07:33:52 PM »
Yeah way ahead of you on that idea. Its on the the list.
