Author Topic: Broken lock tab in carb -cb500  (Read 919 times)
Offline arogers88
« on: May 17, 2015, 01:29:02 PM »
Was adjusting the needle hight on the carb bank and I was just finishing up when I broke that little locking tab that holds the screw in place at the top of the slide. Is this thing necessary? Should I just lock-tite it?
Any help is appreciated.  8)
Offline harisuluv
Re: Broken lock tab in carb -cb500
« Reply #1 on: May 17, 2015, 02:07:25 PM »
It will probably be all right.
On another note, that tang and screw is completely unnecessary to access/change the needle clip.  The two screws at the bottom of the assy connect it to the slide.
Offline arogers88
« Reply #2 on: May 17, 2015, 04:22:23 PM »
Can you access those screws while the carbs are mounted to the bike? Good point though, I'll have to try it. Thanks ;D
Offline harisuluv
« Reply #3 on: May 17, 2015, 05:04:39 PM »
No.
Offline arogers88
« Reply #4 on: May 17, 2015, 06:23:17 PM »
Well its at least a short cut for carb 1 and 4, I don't think 2-3 will have enough room.
