Author Topic: ST90- Goldie's Mighty Green  (Read 7356 times)
Offline goldarrow
  • one day, i'll be an
« on: May 17, 2015, 07:25:33 PM »
I've been wanting one of these and the ct70's since I was a kid, now my wish just came true.
Picked it up this past Friday after work from bike flipper in the area.  Very beat condition.
Then got to work right away. Pics!
I think may be too many pics now...
And the fun began, Weekend went by,  and here's how it looks.
And here's the problem
Cracked left side engine case! Hmm...
CB550 K0
Re: ST90- Goldie's Mighty Green
« Reply #1 on: May 17, 2015, 07:27:43 PM »
That was quick.
Offline goldarrow
« Reply #2 on: May 17, 2015, 07:48:24 PM »
That was quick.
This is when things get slowed down.
Trying to decide
1.  Abandon the project because of cracked case
2. Repair the crack
3. Source another pair of cases and replace
4. Source new motor
CB550 K0
Offline mrbreeze
  • Not your average
« Reply #3 on: May 17, 2015, 09:22:28 PM »
I like choices 3 &4 best. I never knew there was a 90.......only 70's. It shouldn't be too hard to come up with a motor or cases for that. Those little buggers are getting some good dollars.......the little 70's and trail 90's.
MEMBER # 257
« Reply #4 on: May 17, 2015, 09:42:55 PM »
I've never seen a 90, either? Had a 70, and my buddy had one too, so we had a lot of fun "racing" in my back yard. ;D You might look for a cheap Chinese replacement motor, like Tugboat found for the C200 that won this years endurance race.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: May 18, 2015, 12:41:08 PM »
Lifan motor!!! Read my thread here about the Scrapper 24. We ran a [practically new] Lifan 125 for 24 hours straight and it performed beautifully. You can get the motor, intake, carb, CDI & harness for $280 SHIPPED on ebay or dratv.com or tboltusa.com.
Offline goldarrow
« Reply #6 on: May 19, 2015, 06:55:27 PM »
Thanks guys.  I looked into lifan or other Chinese motors, but none are bolt on due to locations of mounting bolts to frame. If ct70's or other trail 90's, no problem.
CB550 K0
Offline goldarrow
« Reply #7 on: May 19, 2015, 07:06:51 PM »
While thinking how far I'm going with this one, probably just gonna make a rider, not show bike, so got one of the forks cleaned up.  Fork internal setup is same as the early 750's, just smaller
CB550 K0
« Reply #8 on: May 20, 2015, 07:53:05 AM »
No way, this need to become a show bike!  No expense spared....
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #9 on: May 20, 2015, 10:51:41 AM »
They  make motor mounting adapters for your bike. Do it!!
http://dratv.stores.yahoo.net/adchtob.html
Offline honda_dog
« Reply #10 on: May 20, 2015, 12:28:08 PM »
I agree.
1978 CB750K
1981 CB900F
1978 Suzuki GS1000E
1981 Suzuki GS1100EX
1980 Suzuki GS1000S (Wes Cooley replica)
1982 Suzuki GS1000S Katana
1982 Suzuki GS1100EZ
1983 Suzuki GS1100ED
1983 Suzuki GS1100ESD
2014 Honda F6B Deluxe
« Reply #11 on: May 20, 2015, 03:06:41 PM »
Hey they make 190 cc for them..might need the adaptors..
Offline goldarrow
« Reply #12 on: May 27, 2015, 08:16:00 PM »
How bout this one
HOT ROD!! BIG BORE + PERFORMANCE CAM!!
54mm high compression piston raising the displacement 20% to 107cc- the largest it can go.
CB550 K0
« Reply #13 on: May 27, 2015, 08:46:20 PM »
Yes!
Online grcamna2
« Reply #14 on: May 27, 2015, 09:19:16 PM »
That's a cool little ST90 goldarrow.I'd install a 4 speed manual clutch big bore motor something like the S90;w/ a small engine it's great to have a manual clutch for powershifting  :)
Offline kap384@telus.net
« Reply #15 on: June 04, 2015, 01:14:13 PM »
My buddy has the exact same bike in minty condition.  He got it for a steal.  Sorry about your cracked case!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #16 on: June 04, 2015, 02:46:25 PM »
Update Goldie?  Lost steam quickly, eh?
Offline goldarrow
« Reply #17 on: June 04, 2015, 03:41:07 PM »
Wait! What! No way!
Got small parts cleaned up and painted!
And waiting impatiently for the big ticket item to come in......
Quoted from the seller.....HONDA ST90 ENGINE - HOT ROD!! BIG BORE + PERFORMANCE CAM!!
This ST90 engine has been completely taken apart, soda-blasted, inspected and professionally re-assembled.  It has a brand new 54mm high compression piston raising the displacement 20% to 107cc- the largest it can go.  All seals and gaskets have been replaced with new as well as new fasteners.  This engine has the stock Honda cylinder that has been professionally machined to match the piston.  The rings have been gapped for top performance.  The stock Honda head features a cast-iron combustion chamber and has been reconditioned with new intake and exhaust valves and a high-lift/long duration cam has been installed.  There are no broken/cracked fins, bungs, mounting points, etc.
CB550 K0
Offline cbornotcb
    • Photobucket link
« Reply #18 on: June 04, 2015, 03:59:28 PM »
You could always think outside the box Goldie ?
Tiny
« Last Edit: June 04, 2015, 04:04:22 PM by cbornotcb »
Offline goldarrow
« Reply #19 on: June 04, 2015, 04:17:57 PM »
Tiny
Now THAT looks pretty interesting.  What motor is that? And what's been done to it? Any info?
CB550 K0
Offline cbornotcb
    • Photobucket link
« Reply #20 on: June 04, 2015, 04:59:31 PM »
Tiny
2 different engines there, the top one was a CB125 which was modified to resemble (loosely) the CT110 engine, a sectioned #4 cylinder and head from a Yamaha FZR600 was grafted on, top speed thus far had been 87 mph
The 2nd pic is a CT110 with an extra 3mm stroke added, and topped with a CB125 head and barrel, good for 71 mph
Tiny
« Reply #21 on: June 05, 2015, 01:15:13 PM »
Congrats on new engine!
Wait! What! No way!
1965 Honda CB450K0
1972 Honda CT70K1
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
Offline goldarrow
« Reply #22 on: June 11, 2015, 06:16:07 PM »
Came home from work, and found big heavy box sitting by the front door, So here's the motor!
And 15 minutes later
CB550 K0
Offline goldarrow
« Reply #23 on: June 14, 2015, 06:14:49 PM »
My 2 yr old son is so eager to ride this
CB550 K0
« Reply #24 on: June 14, 2015, 06:30:28 PM »
Well c'mon, get it running so he can ride!
