McBain,
Not that this means much, but the Swingarm Pivot Bolt is definitely a K6-K8 style bolt.
There are no Zerk Fittings in it from the picture you posted.
The only way I know of to tell about the other parts is to take the Swingarm Pivot Bolt out and look at the Collar.
If the Collar has Spiral Cut grooves and Lube holes an inch or so in from the ends, then the collar is an older style K0-K5 collar.
The pivot point of both swingarms (Old and New Style) is the same. Frame width at that point is the same.
If you look at this post
http://forums.sohc4.net/index.php?topic=29369 you'll see why I said this.
(And since i'm working on my swingarm right now, I figure this is correct.
Hope this helps at least a little.
Charlie
