Author Topic: non responsive throttle  (Read 1666 times)
Offline magnumpi51
« on: May 19, 2015, 01:11:24 PM »
Hi, recently my throttle has no resistance. It just goes right to the full throttle position and it's not pumping out enough fuel to even start it. Is it likely that the throttle cables could have snapped or they somehow got disconnected? Can the cables be adjusted at all? Is it hard to replace the cables if needed? Thanks, any thoughts are appreciated.
Offline magnumpi51
Re: non responsive throttle
« Reply #1 on: May 19, 2015, 01:15:47 PM »
Sorry I forgot to include this, it's a 1978 CB750A
Offline dave the welder
  • dave the welder
« Reply #2 on: May 19, 2015, 07:47:53 PM »
could be broke in the twist part of the throttle.not real hard to change
don't buy it build it
Offline Flyin900
« Reply #3 on: May 20, 2015, 03:13:17 AM »
Turn the throttle and see if the bell crank the part the cables attach to on the carbs is moving open and closed. If not you may have a snapped cable as noted in the throttle assy on the bars or down on the bell crank on the carbs.
It takes a little work to disassemble the switch and replace the cable(s) if that is what is needed. A service manual is a must for working on these older bikes. There may be a free download available from this site in the manuals section.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline magnumpi51
« Reply #4 on: May 22, 2015, 12:03:04 PM »
Thanks a lot guys, I appreciate the info. I'm kind of new to tinkering around with bikes. I'm more used to working on cars and helicopters when I was in the Navy. I'll look into the handle bar side first. I did notice a clicking sound coming from the handle bar when trying to turn it. It didn't make that sound before. I do hear something moving though underneath when I turn the handle. And I did notice one of the cables coming from the handle move a little bit when I turn the handle. I think it was the cable closet to the tank.
