Author Topic: '78 750K first project by a car guy...  (Read 34403 times)
Offline RandyBMC
Re: '78 750K first project by a car guy...
« Reply #25 on: July 30, 2015, 03:41:34 PM »
Got the pistons off the rods and pulled all of the valves/retainers/springs from the head, boxed those, the head and the cylinder up and sent it all off to the machine shop today (Harold's Automotive Machine Shop in Richmond, TX)!  Pretty excited to be making some progress.
Here are some photos of the work:
A little worried about this valve seat - coincidentally (or not), it is the same one that had the piston with the dent in the top.  If it had been damaged, it was obviously reseated enough to allow the valve to close.  Seems to me it was probably rebuilt for a valve issue of some sort in the past.
I can't wait to hear what Harold has to say.  Looking forward to getting it back ready for reassembly!
« Reply #26 on: July 30, 2015, 05:17:44 PM »
Looks good Randy.  Why Harold's? That's on the other side of the world from you.
Offline RandyBMC
« Reply #27 on: July 30, 2015, 06:14:38 PM »
I have been told by more than one source that the guy is an artist, so I called him on the phone.  I like the way the conversation went, so I shipped off my stuff.  I couldn't get a good machine shop recommendation around where I'm located.  I can always drive down if I need (or want) to, so I figured it was a good way to go.
« Reply #28 on: August 02, 2015, 08:22:32 PM »
Thanks!
Will the K0-K6 rings work on the K8 pistons?
Umm...not usually. There are some cheapie rings out there that do, but I don't use them, as they are Chinese knock-offs and not good quality. They may have the K8 rings, though, and Honda does in the stock sizes, too.
Offline RandyBMC
« Reply #29 on: August 06, 2015, 09:30:24 AM »
Got word back from the machine shop.  Not good news.
So that valve on number 3 had smacked the piston.  The valve bent and hit the seat on the head.  Pretty much what I had thought.  When they replaced the valve, it was wron with the wrong keepers and retainer.  The guide was cracked and it wasn't replaced.
Also, the cylinders need 1 over pistons.
So, I need to have the head and cylinders resurfaced, bore the cylinders, a valve job, and new intake and exhaust valves.  That means new pistons are needed (with new rings, wrist pins, etc).
Question now:
CycleX has 2nd over pistons for $199, and they have the 836 Wiseco kit for $449.  It includes the new head gasket too.  Which one?  This is a '78, so I'm worried that I may lose power with the non-domed pistons in the 2nd over kit.  But my budget is now getting seriously stretched....
Input please.  Thanks!
« Reply #30 on: August 06, 2015, 09:51:47 AM »
The Wiseco 836 kit has higher compression and will give you a very noticeable performance gain. A port job will enhance that too, but increase your cost. With all that work I would go with the Wiseco for the incremental cost increase.
« Reply #31 on: August 09, 2015, 07:36:56 PM »
Sorry to hear the bad news, Randy.   Another option is the ebay piston kit from Japan for $130.
There is a thread on here, quite a few guys have used it with success [even Hondaman]
http://www.ebay.com/itm/69-77-HONDA-CB750K-836cc-65mm-BIGBORE-PISTONS-KIT-W-HEAD-GASKET-CI-CB750KBB-/131421590213?hash=item1e995652c5&vxp=mtr
Bottom line, I would def go 836 if you have to bore.  And FYI - around here, $50/hole is the going rate for boring.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #32 on: August 09, 2015, 08:26:03 PM »
They also have 4th over (62mm, 761cc) for the same price ($199). I just completed a K8 rebuild with the 4th over CycleX pistons and it runs great. 500 mile break in complete and am working my way to the next oil change (1500-2000 mi). The dome on the K8 pistons is so slight that any loss in compression or power is probably offset by the slight increase in compression and displacement as a result of the overbore. I think it's a wash.
I'm satisfied with mine and would do it again. Mine can still be bored to 836cc (65mm) or 850cc (65.5mm) if so inclined.
« Last Edit: August 09, 2015, 08:29:53 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline RandyBMC
« Reply #33 on: August 10, 2015, 10:31:28 AM »
After reading 15 pages on the Japan 836 kit, I pulled the trigger on it.  We'll see how it looks, but it sounds decent especially for my budget.
« Reply #34 on: August 10, 2015, 10:37:24 AM »
I've got a set of those too. In keeping with the "budget" theme of my most recent build, I opted for the 62mm (4th over) pistons since I figured I could use the stock cylinder studs with such a mild overbore. The 836 (65mm) pistons will go into my next build with HD cylinder studs, HD valve spring caps, and undercut gears.
TAMTF...
Wilbur
Projects:
« Reply #35 on: August 10, 2015, 11:07:48 AM »
Note:  a 4th over or a cruzinimage 836 kit will increase displacement -- but not compression.  You will get an overall increase in power and torque, but not as much as with a high-compression kit like the Wiseco 836 kit.
« Reply #36 on: August 10, 2015, 12:06:28 PM »
The compression increase is slight as a result of any overbore, provided there have been no changes to the combustion chamber (head). If we were talking about a 76' or older (just for comparison's sake) where you would be going from an old flat top piston to a new flat top piston, after the overbore you would be compressing a greater starting volume (increased cylinder volume as a result of the overbore) into the same size finished volume at TDC (provided the combustion chamber was not changed)
= a theoretical compression increase, even if it's just a little.  ;)
TAMTF...
Wilbur
Projects:
Offline RandyBMC
« Reply #37 on: August 10, 2015, 01:16:45 PM »
I saw that - it should be a slight increase in compression.  The machine shop is also decking the head and cylinders (just to have a perfect surface).  The only worries I have there are cam timing and the size of the inserts for he oil passages - do I have to machine those the same distance as was removed from the cylinder?  And with a stock cam and sprocket, how do I time the cam?
From what I gathered, here are the pertinent numbers and concerns for the Japan 836 kit:
Hand chamfer the oiling holes
Hand file the rings to .012" (about .5mm too big) which is about .002"-.003" more than stock ring gaps
Hand chamfer the holes on the wrist pin feeds underneath
Check for sharp edges on he piston skirt
With the microgrooves the new sets seem to have the piston clearance to the cylinder should be set to .0008"-.0012"
Torque the head stud nuts to 20 ft-lbs (corrected)
Use HD studs
« Last Edit: August 10, 2015, 04:36:33 PM by RandyBMC »
« Reply #38 on: August 10, 2015, 01:34:04 PM »
Slight in comparison to 10.25:1.
« Reply #39 on: August 10, 2015, 01:43:46 PM »
The machine shop is also decking the head and cylinders (just to have a perfect surface).  The only worries I have there are the size of the inserts for he oil passages - do I have to machine those the same distance as was removed from the cylinder?
You would only have to check these if they mill anything off the top of the head (the valve cover surface). Milling is usually only done to the bottom surface that mates to the cylinders. You can check the oil jets by inserting them in the head and use a straight edge to verify that the do not sit "proud" (above) the top of the head surface. If they do (not likely) a few passes with a hand file across the top should eliminate any potential interference with the cam tower. Only take off what is needed to make them flush. Again, I do not believe this would be necessary....
but I've been wrong before!
You could grind the bolt holes in the stock sprocket into an oblong shape. The alternative would be to procure an adjustable cam sprocket with the holes already slotted ($35 from A.P.E). I would install the stock sprocket first and check the cam lobe degrees. If they are off by more than a couple of degrees then you can decide whether you want to slot the stock sprocket or buy one already slotted.
Torque the head studs and extra 20 ft-lbs
Use HD studs
Yep, that's pretty much what I gathered as well, but the torque reading is misrepresented. The new torque value for HD studs would be 20 ft/lbs. If you were to use an extra 20 ft/lbs then your torque value would be 35 ft/lbs (15 ft/lbs plus an extra 20 ft/lbs would be 35 ft/lbs). Way too high.
I suggest that the extra torque only be applied to the HD studs (which appears to be implied). Some have applied higher torque to the stock studs without problems, while others have snapped them off at stock torque
TAMTF...
Wilbur
Projects:
« Reply #40 on: August 10, 2015, 02:06:19 PM »
A little clarification: randy are you referring to the knock pins between the cylinders and the head, or the oil passages? My reference was to trimming the knock pins, but said oil jets (550 feature). Wilbur is correct, the oil passages are in the head above..
Oh yeah! Most definitely check ALL dowels (or knock pins) for proper length. You can test fit the head, or break out the calipers measuring the dowel lengths vs the dowel bore depths.
TAMTF...
Wilbur
Projects:
Offline RandyBMC
« Reply #41 on: August 10, 2015, 02:10:31 PM »
Knock pins.  I believe I even read at one point that the knock pins weren't totally necessary (maybe at the Cycle X website?), but I would rather use them.
I believe it was HondaMan that said the torque value should be given an extra 20 ft-lbs, and I believe I may have misspoke.  It would be the torque of the nut on the stud, not the stud itself.
« Reply #42 on: August 10, 2015, 02:20:46 PM »
Those would be the dowels where the rubber "barrel" seals are used at the oil returns. I'm with you, I would use them too. There are also two alignment dowels at the front corners between the head and cylinders. I highly recommend that those be used.
All dowels, whether at the oil returns or at the alignment dowel position, should be checked for length. The knock pins (at the oil returns) should finish flush with the head surface. They could extend above, but no more than the compressed thickness of the head gasket! I would just make sure they finish flush.
As for the alignment dowels, they must extend into both the cylinders and up into the head. Here is where I add the bores in the head and cylinders and compare them to the length of the dowel.
Correct.
TAMTF...
Wilbur
Projects:
Offline RandyBMC
« Reply #43 on: August 10, 2015, 05:13:48 PM »
Since I got such a great deal on the pistons from asking here - any good suggestions on heavy duty valve spring retainers?
« Reply #44 on: August 10, 2015, 05:19:54 PM »
Try APE Engineering, they have titanium retainers for our bikes.. Half way down the page.
http://cbrzone.com/sohc.html
« Reply #45 on: August 10, 2015, 05:26:44 PM »
As far as I know, the titanium retainers require the use of the early style valve keepers, which require changing valves or having the later model valve stem machined for the early keepers. You might need to contact A.P.E. to verify. The only heavy duty retainers that I am aware of that are designed to work with the late model keepers are those at CycleX:
http://www.cyclexchange.net/Honda%20cb750%20(%2077-78%20)%20%20F%202%20Section%20Page.htm
but I could be wrong, I've been wrong before! The CycleX retainers are on my list for the next late model build.
The F2, K7 and K8 use the same retainers/keepers
« Last Edit: August 10, 2015, 05:41:35 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline RandyBMC
« Reply #46 on: October 02, 2015, 04:36:35 PM »
I've been working quite a bit lately on the bike.
No photos yet, but I took some (just didn't upload to Photobucket yet).  I like the Japanese 836 kit from what I've seen so far.  They came rather nice out of the box.  The machine shop finished up all of the recommendations for them.  They also did the head (I ended up with the CycleX heavy duty retainers and associated keepers and their super flow valves).  It all looks very pretty.
I did all the taping, stripping, and painting of the engine block, the cylinders and other miscellaneous bits and pieces.  I used the Duplicolor Semi-gloss Black engine paint.  Turned out clean, and with the polished covers should look pretty stunning.  Polishing is not fun for your neck and back and hands if you didn't know.  Getting old is not a good deal.
I stripped the tank I bought from Steve-o, and it is almost perfect underneath - no rust at all!  I understand the pull toward using clear coat on the tank when it looks that clean (but I still plan to paint it).
Now in at the reassembly point for the engine.  While the machine shop did a great job on the end gap for the rings, they took them out of the wrapper (which conveniently had a top ring label) and didn't label them.  I am guessing the silver edged ring is the top ring and the black is the other.  Anyone with these confirm which rings go where?  There is no stamping or marking on them that shows which way is up, but I think I can figure that one out by edge shape with a magnifier.  HELP please!
Thanks!
(Photos to follow when I have some time)
Offline RandyBMC
« Reply #47 on: October 02, 2015, 05:34:30 PM »
The silver ring is the top ring, just looking at the chamfered edge on the top and bottom.  The second ring, however, looks identical on both top and bottom - I can't really see a "scraper" slant.
Waiting for ideas...
« Reply #48 on: October 02, 2015, 07:12:03 PM »
Sorry, can't help you with the rings.
But, to post pics, you can now attach as an attachment.  Look below the white box after you hit reply.
Offline FGKouki
« Reply #49 on: October 02, 2015, 07:21:25 PM »
Almost always the rings will have a number or letter and that signifies the TOP side.  Otherwise you may have to get out some reading glasses and look at the profile where you have your gap.
