Author Topic: 1973 CB350F Build Log -- First Bike -- FINALLY FINISHED!!!  (Read 20357 times)
Re: 1973 CB350F Build Log -- First Bike -- Army Green Cafe Style
« Reply #25 on: June 02, 2015, 11:15:42 PM »
Have you considered cutting right after the collectors and installing new mufflers like the ones from Cone Engineering. You could order them relatively cheaply and have your local welding shop weld them up.  You may even have a bend inserted so they provide some additional ground/cornering clearance.
For $60 I could get two condensers, have them welded to the headers and then put an aftermarket exhaust on it.  Would have to be really confident about this as a solution before cutting my headers.  Do you know of anyone who has tried this before?
I'm not sure where you are but I've seen shops and builders here use aftermarket exhausts fastened to stock and aftermarket headers.
Offline GizmoDuck
« Reply #26 on: June 03, 2015, 06:08:53 AM »
What did you use on those pipes to clean them like that?
This
http://www.lowes.com/pd_59859-98-7772MASS_0__?productId=3036320&Ntt=
Then this
http://www.lowes.com/pd_335867-98-10110NA-PT___?productId=3561774&pl=1&Ntt=3m+paint
They make progressively softer pads to smoothe out surface.  There is a good deal of scratching, I could eventually buff out but my main concern was removing rust to possibly paint them black
Offline GizmoDuck
« Reply #27 on: June 03, 2015, 11:18:12 AM »
Taking everything apart to paint the frame and begin rebuilding
« Last Edit: June 03, 2015, 11:19:50 AM by GizmoDuck »
« Reply #28 on: June 03, 2015, 01:17:57 PM »
You may also consider powder coating the frame.  It is much more durable than paint and resistant to chemicals, gas, etc.
You mentioned using ammo cans as panniers.  Check out this build:  http://www.lossaengineering.com/blogs/bikes/18846563-honda-cl450-for-sale
Jay LaRossa also installed solar panels on the tops of the cans to USB chargers (charge you phone etc) from a company that makes charging backpacks.
Offline GizmoDuck
« Reply #29 on: June 04, 2015, 04:16:50 AM »
oh man that build is amazing! Thanks for that. I am trying to figure out how to bolt on the ammo cans while avoiding too much fabrication work.
I really want to powder coat the frame but it is way out of my price range, most places gave me an estimate of around $200 to media blast and coat the frame. I think the frame paint I am using should give me good durability and I can always coat it in the future if I strike it rich :)
Offline GizmoDuck
« Reply #30 on: June 04, 2015, 10:27:36 AM »
Got the motor out will get everything else off the frame this weekend and paint sometime in the next two weeks then will redo brakes, suspension, forks, and start putting it back together.  Any thoughts on what I should do to the motor since it is out of the frame?  Nothing appears to leak and I have seen gasket sets for $50 so should I pull apart the motor and do those?  Any tips for cleaning the motor exterior it is filthy?
« Reply #31 on: June 04, 2015, 10:59:58 AM »
If it doesn't leak or make any irregular noise (cam chain noise, etc.), then I would suggest cleaning it with Simple Green and maybe a wire wheel brush, and painting it with VHT.  If there is nothing wrong with the engine and it isn't leaking, there is not need to crack it open.  Count your blessings.
Offline P-cola Four
« Reply #32 on: June 04, 2015, 07:10:51 PM »
Following, as I too have a 350F that I'm in the process of bringing back to life.  ::)
You have a great plan and hopefully we'll both get our bikes running on a budget.  ;) Good luck!
1973 Honda CB350F
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #33 on: June 04, 2015, 07:51:55 PM »
Sorry if its been said already but did you do a compression test already? If everything checks out adjust your valves while the engine is out, make sure to get new Exhaust gaskets to.
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline GizmoDuck
« Reply #34 on: June 05, 2015, 02:14:49 PM »
Nearing the end of the tear down
Offline WhyNot2
  • I'm finally an
« Reply #35 on: June 05, 2015, 03:39:09 PM »
I'm watching to see what ideals for the exhaust surface.
Want to see how the build goes. Looks like you're on the right track.
Offline GizmoDuck
« Reply #36 on: June 05, 2015, 07:05:07 PM »
Trying to get some help on the forums nailing down my to do list so I can budget for the rest of the build.  Here is the link for that discussion http://forums.sohc4.net/index.php/topic,148486.0.html
Offline Trad
« Reply #37 on: June 05, 2015, 09:35:00 PM »
Compression test for sure if you haven't. In for progress  :D
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline GizmoDuck
« Reply #38 on: June 06, 2015, 12:04:54 PM »
I am so new to this I had not heard of compression testing.  Looked it up seems simple enough to check.
Offline GizmoDuck
« Reply #39 on: June 06, 2015, 12:08:38 PM »
Stripping the frame and swingarm
Offline GizmoDuck
« Reply #40 on: June 06, 2015, 01:21:32 PM »
Before you powder cost the frame, knock the steering bearing races out of the neck (top and bottom). Also, grind the rivets off that hold the vin tag on, and remove it carefully. Then reinstall with new rivets.
You can use some monofilament line as a "saw" and slip it behind the tag, then saw back and forth to help separate it from the neck (there's 40 year old adhesive keeping it on).
Any good place to get those rivets after I remove them?
« Reply #41 on: June 06, 2015, 02:08:16 PM »
You can get a rivet kit at Harbor Freight or Home Depot.  This will preserve the VIN Tag and Stamp -- good if you ever sell the bike.
Offline GizmoDuck
« Reply #42 on: June 09, 2015, 09:48:41 AM »
Final Stripping
Rust Neutralizer
Primer
Paint
« Reply #43 on: June 09, 2015, 10:03:57 AM »
Any de-tabbing prior to coating?
Offline GizmoDuck
« Reply #44 on: June 09, 2015, 02:06:38 PM »
Just the seat hinges and lock and the tab opposite the helmet hook left everything else. I didn't want to modify the frame too much. Probably making a customs seat can't.seem to find one that works with the original fender mount on the back. Cannot afford to pay anyone to weld a rear hoop so I am going to trim the stock fender and have the seat real snug against its curves to create a clean look.
Offline GizmoDuck
« Reply #45 on: June 10, 2015, 09:48:54 AM »
Painted
Offline GizmoDuck
« Reply #46 on: June 10, 2015, 09:50:16 AM »
Cut down the spring guards to expose more of the spring and noticed that one of the shocks was bent.  I guess that means it should be replaced right?
« Reply #47 on: June 10, 2015, 10:05:42 AM »
The matte paint on the frame is nice.  That shock is shot.  I would just buy a set of Hagons for it.
Offline GizmoDuck
« Last Edit: July 04, 2015, 08:38:29 PM by GizmoDuck »
« Reply #49 on: June 10, 2015, 12:14:24 PM »
Would these work? They are an inch shorter than stock.
For unknown reasons, you picture is not coming through on my browser.  The image link is for an Emgo shorty shock.  The Emgo stuff is cheap but I would not use their shocks.  If you have stringent budget issues, look at the Hagons or even the Progressive shocks.  A shorty shock will also disturb the handling of the bike.
