Author Topic: Mulling over clutch easement options.  (Read 1564 times)
Offline Lostboy Steve
« on: May 27, 2015, 10:38:58 AM »
I'm still having issues with the clutch. I took everything apart, everything is in order. I can only blame the EBC springs. They must be stiffer. Anyway, I would love to live with it but my tendonitis makes it nearly impossible to ride. I've been having to commute on my wr250r for this reason.  I've decided to make a device, similar to the 'Moose ez pull" contraption, to ease the pull by way of leverage. I don't want to change the controls so having a hydraulic lever is not an option, however I have thought about making the stock cable connect to a hydraulic device. Any ideas or pictures of similar setups would be greatly appreciated.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
    • http://forums.sohc4.net/index.php?PHPSESSID=7g5fu5tl9t57jutb0rd3fg6as0&/topic,60973.0.html
Re: Mulling over clutch easement options.
« Reply #1 on: May 27, 2015, 11:34:43 AM »
BMW used a kombined handel.. hyd-/brake set up..by a kabel manovred master mounted under the tank..a bit krazy..and dont think.. it can be used..but as inspiration...
« Reply #2 on: May 27, 2015, 12:58:24 PM »
Yeah thats pretty much what i was thinking about doing. Should make operation easier. Thank You!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Dunk
« Reply #3 on: May 28, 2015, 07:41:10 AM »
Curious to see options. I sometimes get the same pain.
« Reply #4 on: May 28, 2015, 08:02:18 AM »
Yeah man. Its debilitating. From my fingertips to my shoulder. I did see some pretty radical designs out there.
I suppose you could go the magura route... but i dont know if it will have enough travel.
Then I saw this, similar to what strynboen was talking about...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #5 on: May 28, 2015, 08:05:25 AM »
I could also probably just lengthen the actual clutch arm a bit to provide more leverage.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #6 on: May 28, 2015, 09:26:41 AM »
yes made a longer arm on the engine part..if there are Space to do it..10 mm longer arm vill give some gearing
« Reply #7 on: May 28, 2015, 12:49:24 PM »
Maybe I will play around with that option first.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
