Author Topic: Powder Coating or Spray Paint  (Read 5095 times)
Offline AlekStooge
  • can't afford cheap stuff
Re: Powder Coating or Spray Paint
« Reply #25 on: June 06, 2015, 09:35:17 AM »
This is my tank after powdercoat. I think it turned out nice, other than the lock and spring melting!
Offline Powderman
« Reply #26 on: June 06, 2015, 09:52:49 AM »
If you are going to have a quality PC shop do a frame, swing arm and triple tree, from prep to bake, it's gonna be $450-$500.  You go to a shop that just wipes, applies and bakes, the stuffs gonna peel off within a year.  IMHO, paint is the way to go.  You pay a good shop to blast your parts and use Eastwood Chassis black to cover it.  It will last as long as PC providing you prep the parts correctly before painting.  Vent well and you can get away with 1 can of primer and 2 cans of paint.  Cost around $100 with shipping.  Quality an longevity of any paint job, on any part is directly related to the quality of your prep.  You get what you pay for with PC.
Works both ways. replace PC with paint and paint with PC in your post and it says the same thing. Both are you get what you pay for. PC has advantages over paint, this can't be argued. If your paint lasted  a long time, PC would last as long if not more. If your paint lasted years then the issue of chip fix becomes moot because the chances of chipping correctly done powder is very slim. Paint is environmentally hazardous.
Offline Dos
  • Owner of a cb350f
« Reply #27 on: June 09, 2015, 10:21:02 AM »
Hello all,
I got it sandblasted and powder coated for 200 dollars..
When i first went to pick it up, oil started coming up through the frame
So they did it again and I came back and it looks great.. I just have to punch through the rear wheel adjuster
« Reply #28 on: June 09, 2015, 01:37:04 PM »
Hello all,
pics !  :D
