Author Topic: CB750K2 oil pan removal  (Read 1060 times)
Offline jeremyillingworth
« on: May 31, 2015, 12:15:55 PM »
I'm in the midst of my 6000 mile tune up and got to pull the oil pan. Does anybody else have trouble with the bolt next to the oil drain plug? It's so close to the pan I can't get a socket on it. Eventually I had to do the unthinkable and use vice grips to break it free and then was able to use a stubby wrench to get it out.
After the bolts were free the #3 muffler prevented it from coming out; I'm guessing it's a bit bent, so I pulled the bolt from the back and made room.
After seeing the stuff hanging from the screen I'm guessing the difficult bolt had been deterring others from dropping the pan for quite a while. The screen didn't seem interested in coming out easily, so I cleaned it in place and noticed a small tear in the screen, so I'm doing this all over again when the new one arrives.
Is this small amount of black particles normal? There were also a couple of bits of aluminum but not many.
jeremy
Offline edwardmorris
  • Youngish
Re: CB750K2 oil pan removal
« Reply #1 on: May 31, 2015, 03:28:28 PM »
I did have trouble with that bolt even with the engine out of the frame. I had to use a thin wall socket on that.
Offline Davez134
« Reply #2 on: May 31, 2015, 07:08:49 PM »
Those black particles are most likely from primary tensioner wheel, and cam tensioner. Would not worry much about those. What do you mean by bits of aluminum? How big?
« Reply #3 on: May 31, 2015, 09:44:44 PM »
Now I'm going to have to track down a single 10mm thin wall socket.
The aluminum particles were similar to the medium sized plastic bits. They were quite thin. What do you think they might be?
« Reply #4 on: June 01, 2015, 04:50:12 AM »
A 1/4" drive socket may fit on that bolt head or grind down a donor a little.
Offline Eydugstr
« Reply #5 on: June 01, 2015, 06:25:46 AM »
+1 on the 1/4" drive socket.  Recently swapped out oil pumps, and used a 1/4" craftsman deep socket, no grinding necessary.
« Reply #6 on: June 01, 2015, 06:34:07 AM »
I was already using a 1/4" drive socket; I guess Canadian Tire sockets are a bit thick walled.
Offline Chachi
« Reply #7 on: June 01, 2015, 06:57:39 AM »
I had the same issue on my 750 K3. I think it was the same bolt location. Odd thing is, the first time I dropped pan I did it with pipes on and I don't remember having the issue, but the second time I dropped pan I had the pipes removed and that's when I was unable to tighten that one bolt the way I wanted. The MM socket wouldn't grab it and I couldn't get the wrench to it due to hitting the frame or side stand. I didn't try a 1/4". It's not leaking, so it's OK, but it was annoying to say the least.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #8 on: June 01, 2015, 08:21:23 AM »
I also used a mastercraft (Cdn Tire) 1/4" drive deep 10mm on mine. Fit no problem.
When you go to put your pan back on, put that bolt in first and just one-finger tight with your ratchet. There might be just enough side-to-side play that the socket will fit when you put it on first.
« Last Edit: June 01, 2015, 08:22:56 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline Chachi
« Reply #9 on: June 01, 2015, 08:59:09 AM »
That might be why I didn't experience it the first time I dropped the pan now that I think about it. I know that was the last bolt I got to when I dropped the pan the second time and had the same issue.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
