Author Topic: Yamaha DS6 New Project FINI THE END MY FRIEND  (Read 24910 times)
Offline MoMo
  • Ride like you're invisible
Re: Yamaha DS6 New Project FIRE repair finished and bike STARTED
« Reply #100 on: August 23, 2015, 04:22:16 AM »
Wow, that clutch was something else:)
Nice progress, sir ;D
Progress is one step forward then two back. Hopefully the switch gets here soon and I can button this up and get it off the lift, or buy another lift
« Reply #101 on: August 23, 2015, 05:16:45 AM »
You know your Lenin, Larry  ;D
 Šag vperjod, dva šaga nazad.
Offline MoMo
« Reply #102 on: August 23, 2015, 07:25:48 PM »
Yep, I'm one of the useful idiots :P a product of the wonderful public school system
« Reply #103 on: August 23, 2015, 07:30:40 PM »
2 lifts ! Yeah  :)  I once had 2 Western Handy lifts but not enough shop space..
« Reply #104 on: August 23, 2015, 07:48:57 PM »
Goos work Larry, I've had a leaking neutral switch on my CB750 for years, but I figure it keeps the concrete lubricated, so I leave it, I'd hate for my concrete to seize................ ;D
Offline MoMo
« Reply #105 on: August 23, 2015, 07:58:44 PM »
Plus CSI can follow you by tracking your oil drips..
Offline MoMo
« Reply #106 on: August 23, 2015, 08:00:45 PM »
Looking at a Handy, available new down in Newark, De for a shade over 700.  Would be waaay sturdier than my rickety HF model
« Reply #107 on: August 23, 2015, 08:30:05 PM »
Larry,
That Handy is made in USA in Iowa and Real rugged.I had mine on an un-even concrete floor for a few years w/  no issues,even when a 1000 lb. Goldwing was almost tipping over as the lift lowered and I forgot that I had it tied to a rafter on one handlebar for some work on the front end..  :o (I saved it w/o getting crushed in the process but it was close)
I saved the bike and it wasn't touched and didn't fall but the lift had a slight bend in the frame from that time on.  ::)
I ended up selling that one to the local 'high times' Harley repairman,no sweat.
They make accessories for it so you can work on ATV's and extenders so you can put the long cruiser style & Valkyries up there too w/ a good quality front wheel vise that works w/ sportbike front rotors;you should squirt a little light oil into the air cylinder(which will work even w/ a low cfm/small volume tank compressor)once a month to keep the seal-ring pliable and maintained.
Offline MoMo
« Reply #108 on: August 23, 2015, 08:50:29 PM »
Thought the lift available was a Handy but it is Atlas...Larry
« Reply #109 on: August 23, 2015, 09:35:53 PM »
Hydraulic oil is probably more seal friendly if you are dealing with lubing a hydraulic cylinder.  If it is air operated it is probably lube friendly seals but if not, then you may be causing damage to a seal that does not tolerate oil. Granted, it takes time for those kind of problems to show up.
David
PS curious what makes the HF rickety? Is it sloppy joints or what?
Offline MoMo
« Reply #110 on: August 23, 2015, 09:48:24 PM »
David
rickety compared to the higher quality ones I used in the dealerships, but I only paid less than 300 when purchased 5 or so years ago.   It is OK but I'd like to get a better one if I buy another
« Reply #111 on: August 24, 2015, 01:15:53 AM »
The one I've got looks like the HF lifts, it is rickety. If they used larger diameter rectangular tubing there's be less "side to side" movement, but to be fair, I never had an issue with mine until I left the "prop bar" out for a week or two with a CB750 on it at full height. I walked into my garage to find the lift fully collapsed, with a pool of hydraulic fluid underneath. Oops........... ;D
« Reply #112 on: August 24, 2015, 05:31:24 AM »
David
Daviv,
The info that I mentioned to Larry about lubing the air cylinder w/ "a few squirts of oil" came straight from the manufacturer in IA. and I used ATF myself. They told me any oil on the seal ring is better than leaving it dry.
Offline MoMo
« Reply #113 on: August 24, 2015, 05:45:11 AM »
whoops is right,  I had the lift lower on its own once but all in all I am very satisfied except for the side to side play and I'd like it to be a bit wider.  I am thinking of bolting an extension to one side..G'day
« Reply #114 on: August 24, 2015, 04:39:13 PM »
Terry, rather than diameter you should use cross-section , I know more words and I'm being picky...just trying to wrap my head around circular diameter and square tubing.  ;)
You use a bigger hammer to pound it home?
« Reply #115 on: August 24, 2015, 04:40:49 PM »
Momo, I have plans for making a lift out of wood and using a large floor jack to raise and lower it...
« Reply #116 on: August 24, 2015, 04:41:20 PM »
Oops........... ;D
... all in all I am very satisfied except for the side to side play and I'd like it to be a bit wider.
Thats what she said!!
« Reply #117 on: August 24, 2015, 04:58:02 PM »
Oops........... ;D
You got a dirty mind and I think I like it !!   ;)
Offline MoMo
« Reply #118 on: August 24, 2015, 06:11:07 PM »
Just got in from work and found the new neutral switch in the mailbox. Off tomorrow, hoping to button this up and have it out by the end of the day.  That is, unless........................................?
« Reply #119 on: August 24, 2015, 06:58:10 PM »
Oops........... ;D
So, MoMo is satisfying her, it is just she wants a little more.
« Last Edit: August 24, 2015, 07:01:56 PM by RAF122S »
Offline MoMo
Re: Yamaha DS6 New Project FINI THE END MY FRIEND
« Reply #120 on: August 25, 2015, 12:12:29 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
this  is the end beautiful friend, this is the end ,my only friend, the end .
This bike put up a fight to the bitter end.  Put the neutral switch in, filled with oil(refuse to divulge what type so this doesn't   turn into an oil thread) ::), and took for a test ride.  Yes, the clutch cleaning repair worked fine but the rear brake light decided to quit. New bulb and on the  truck headed back to the owner.
http://i705.photobucket.com/albums/ww51/photolar/ds6/ds%20013_zpshpmuvg85.jpg
more photos to follow ...Larry
« Reply #121 on: August 25, 2015, 03:01:40 PM »
Payday!  First virtual round is on MoMo!
Congrats on finishing up the beast. I guess he didn't want stripes on the tank, or he's having them put on later.
Hope the blendzall works its wonders.
David
Offline MoMo
« Reply #122 on: August 25, 2015, 09:16:41 PM »
David
He has a friend who does pinstriping,, still think he's going with silver rather than the standard white.   More photos of the finished stubborn mule
Offline MoMo
« Reply #123 on: August 25, 2015, 09:28:44 PM »
Last photo, waiting to be unloaded at the owner's shop ;D
« Reply #124 on: August 26, 2015, 05:17:44 AM »
How did she run Larry ?
