Author Topic: torque value conversions  (Read 1432 times)
Offline 01Thomas
« on: June 02, 2015, 12:13:08 PM »
Hi
I'm installing HD cylinder studs on my CB750 and the value for tightening the studs into the crankcase is 17 to 18 ft-pounds. My click-type torque-wrench is calibrated in inch-pounds.
I grew up in a metric environment, sooo... am I correct in thinking 17 ft-pds = 204 inch-pounds?
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Re: torque value conversions
« Reply #1 on: June 02, 2015, 12:23:50 PM »
You'll find conversion calculators on Internet. I convert ft lbs to Nm.  ft lbs vs Nm  on Google
The studs only should be tightened with 8 ft lbs. Head on torque about 22 ft lbs.
I torqued about 28Nm as final torque with a new and calibrated wrench.
Do not torque too much. HD studs are rigid and can snap if you torque too much... I have done it
« Reply #2 on: June 02, 2015, 12:26:53 PM »
12 inches in 1 foot :)
Offline 01Thomas
« Reply #3 on: June 02, 2015, 01:35:38 PM »
Hi Pewe
The instructions which came with the Kibblewhite HD studs clearly state "17 to 18 ft-lbs". Where does 8 ft-lbs come from?
See the attached PDF file.
regards
Thomas
« Reply #4 on: June 02, 2015, 01:39:22 PM »
17-18ftlbs might remove your threads  :o
8ftlbs is standard for studs.
Offline 01Thomas
« Reply #5 on: June 02, 2015, 02:17:22 PM »
OK, I'll go with that. Thanks.
