Author Topic: Advice needed....am I running lean?  (Read 2867 times)
Offline redlabel
  • Honda CB400f F0
    • brunsame
« on: June 02, 2015, 02:54:08 PM »
Hi!
I am currently running my CB400F with pods and a straight slash cut pipe. Pilot #38, Main #90 and mix scre 1 1\2 turn out....I haven't moved the clip on the needle(Maybe I should have?)
The bike is not the easiest to start and doesn't idle very nice. When I am on the road she pulls good without hessitation, but alot of popping trough the exhaust on deceleration. This normaly indicates a lean mix, but original main jet is #75 so I would think that #90 should be big enough. It runs hot after "long" runs and if I stop after an 40-60min run, she wont start before it cools. New coils and ignition.
Cylinder 2 is not in sync with the other carbs it appears....
Offline Powderman
Re: Advice needed....am I running lean?
« Reply #1 on: June 02, 2015, 03:31:14 PM »
Yes. What did you expect with that combination of pipe and filter?
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #2 on: June 02, 2015, 03:44:57 PM »
I expectet to run lean.......that's why i changed the mains to #90. :p
I have read of others with same setup that is running fine on #85 mains.
Offline mcswny
« Reply #3 on: June 02, 2015, 05:24:35 PM »
Well at least she looks nice?
I would start by setting your idle mixture screws and give yourself a good sync. I don't know much about jetting for pods/open pipes. But if your saying you know plenty of people that are running well with #85s, it sounds like it could be with your idle mixtures? Just a thought.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline harisuluv
« Reply #4 on: June 02, 2015, 06:37:32 PM »
yeah you already alluded to the needle clip position issue.  unfortunately changing your main jet only predominantly affects 3/4 - WOT.  Needle clip position is 1/4-3/4, or in other words, the majority of your throttle band.
Stock is 3/5, so you should be at 4/5 (from top) to help your problem.  A vacuum sync is probably in order too.
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #5 on: June 03, 2015, 12:20:22 AM »
Thanks guys! I thought it could be the clip yes....not sure why I didn't change that when jetting it. Probably a naging misses og one of the kids baning their head on something.....
I did a sync last week, but will adjust needle and do anotherone. I am aslo ditching the pods and putting in Uni foam filters.
Man I love this place! TY!
Offline Deltarider
« Reply #6 on: June 03, 2015, 12:35:38 AM »
Yeah, I agree, make sure your lungs work simultaneously and are not fighting eachother.  ;D
CB500K2-ED Excel black
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #7 on: June 03, 2015, 05:24:01 AM »
Offline Rgconner
« Reply #8 on: June 03, 2015, 07:57:24 AM »
I don't understand why they went with pods when they did not even open up the frame triangle.
Kinda pointless.
1975 CB550K aka "Grease Monkey"
« Reply #9 on: June 03, 2015, 09:28:20 AM »
90 mains are fine.  you're getting some gas, but only above 1/2 throttle.  this is why it accels fine here....
ditch those expensive iridium plugs and run plain NGK D8EA plugs.
#40 pilots
air screw at 1 turn out
lower the needle clip one slot.
retest.
« Last Edit: June 03, 2015, 09:51:19 AM by flybox1 »
Offline harisuluv
« Reply #10 on: June 03, 2015, 10:09:01 AM »
uni foam filters (plural).  you mean uni foam.. pods?
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #11 on: June 03, 2015, 02:58:51 PM »
Say what now?! I am changing out the K&N copy pods for 4! UNI foam air filterS. Is there something wrong with the grammar? I'm from Norway, so english is not my native language.....
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #12 on: June 03, 2015, 03:01:24 PM »
Kinda pointless.
What's pointless is your post, good sir.
I went with pods to make her breath easier and because I liked the look of the pods.
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #13 on: June 03, 2015, 03:04:51 PM »
#40 pilots
retest.
Hi.
Why should I ditch the iridium? I wont get my money back, so is there a reason why I should run the standard D8EA instead?
So I should change my #38 pilot back to stock #40?
« Reply #14 on: June 03, 2015, 03:14:14 PM »
Your grammar is fine, redlable  ;D
D8EA's are closest to what was originally recommended by HONDA. (DensoX24ES-U)
I cant say i know of many who have had noticeable improvement with the Iridiums to be worth the extra expense.
You're going to want to perform some plug chops anyway, to get your jetting correct....and with fresh plugs at each step.  D8EA's are much cheaper.
At idle and up to 1/3 throttle, does your bike perform better with a little choke?  This is a test for lean idle/pilot circuit.
if your performance improves at low throttle positions, your 40's pilots should be really close to getting your mixture here correct.
Offline Rgconner
« Reply #15 on: June 04, 2015, 07:10:03 AM »
Kinda pointless.
Because the bikes, and you can read about it on this site in many posts, makes getting idle and mains difficult to tune.
The bike was intended to run with "still air" from the airbox, not from pods. The air from pods tends to be turbulent and causes rough idle or stumbling on acceleration.
A 400 is unlikely to be air restricted from the airbox if the filter is maintained.
Straight pipes are going to complicate the process even more.... but hey, it looks good!
Everything you ever wanted to know about SOHC4 carbs:
http://forums.sohc4.net/index.php?topic=5410.0
