The CruisinImage 836 rings are non-directional. Do you have any idea what clearance the shop gave those pistons? Too many try to give them .0020" or more, which is very close to the worn-out limit for the engine. These pistons needs .0008"-.0012" clearance, no more.
I recently (last year) had to fix an 836 engine just like yours: the owner's machine shop bored them to .0025" clearance. After 100 miles, the bores were nearly .0030" loose. It pumped oil out the exhaust pipes, it was so wet.
The valve guides on these engines are frequently worn, thanks now to ethanol. It can wear them more than .0010" in just 10,000 miles, mine proved it. In 2006 I tore the top end off to measure things after it sat for 5 years after I had cancer: the pistons were at .0016" clearance at 126,000 miles, so they got new rings. The valve guides were all less than .0018" clearance worst case, so I kept them. By 2012, with the ethanol gas here in Colorado, the bike started using oil. I suspected the rings (was wrong), took it down for a full rebuild at 138k miles. The guides were severely worn, which all happened in the 12k miles in between (even using top oil in most fillups!).
Bronze guides will go a long way toward solving this issue. The clearance is very important: I build all my engines to .0008"-.0012" intake guide and .0014"-.0016" exhaust guide clearances, except my own: I went to .0008" intake and .0012"-.0014" exhaust. The performance is stellar, and it is smoother than it ever was before! It so easily tops 100 MPH I have to watch myself: it feels like a liter bike(!) all of a sudden, so I put a 19T front sprocket on it to tame it down a bit.
