Author Topic: 1976 Honda CB550 Engine compatibility  (Read 1368 times)
Offline Spiderbath
« on: June 08, 2015, 03:13:15 PM »
I'm working on a 76 honda cb550 and was wondering if a 1975 cylinder head would fit on it or a 74. Is there a place I can go to find out what other parts are interchangeable with other years? Thanks!
Re: 1976 Honda CB550 Engine compatibility
« Reply #1 on: June 08, 2015, 03:31:52 PM »
The heads are the same.  You can check the parts fiche to see if the part number are the same......
Offline Spiderbath
« Reply #2 on: June 08, 2015, 05:19:04 PM »
I forgot about using parts fiche, thanks!!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: June 08, 2015, 06:31:37 PM »
There were some improvements in the rocker arm assembly on the 77-78 engines, but the heads should still interchange
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #4 on: June 09, 2015, 12:06:44 AM »
i haven't found any diffs in heads for any of the cb550s yet. Rocker boxes changed  to the pinned shaft type in 77 (or was it 76)?
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline Deltarider
« Reply #5 on: June 09, 2015, 12:34:56 AM »
For once and for all, will you guys please stop communicating in years? The inaccuracy and errors I read here, it's just unbelievable. If you don't know what you're talking about, stifle it.
For comparison look here at an answer I just gave. http://forums.sohc4.net/index.php/topic,148598.msg1693836.html#msg1693836
I recommend consulting Parts Lists over these fiches because the latter lack the overall overview.
« Last Edit: June 09, 2015, 12:38:10 AM by Deltarider »
CB500K2-ED Excel black
