Author Topic: '81 CB650C air box cover screw stuck  (Read 817 times)
Offline snowfighter2
  • I really like Motorcycles, I guess that makes me an
« on: June 15, 2015, 06:51:56 AM »
Hey guys I tried to take my air box cover off to service the filter and one of them is stuck in the threaded insert that is embedded in the plastic air box. The screw and the insert just spin in the plastic. I can swivel the cover open to access the filter. I want to know if this has happened to anyone else, and what did you do?
Andrew
That which does not kill you, will give you some awesome scabs, which turn into some cool scars!
1975 CB750K5
1985 GS 450E
1981 CB650 Custom
Re: '81 CB650C air box cover screw stuck
« Reply #1 on: June 21, 2015, 09:58:35 PM »
Yeah! That method that one guy suggested worked like a charm! I cant believe how simple that was! The screw came right out the first time! Man, I should have thought of this days ago!
Andrew
1975 CB750K5
1985 GS 450E
1981 CB650 Custom
Offline cb650
« Reply #2 on: June 22, 2015, 05:32:58 AM »
What did u do?   I have never had that happen and was at a loss short of destruction or swapping boxes.
« Reply #3 on: June 22, 2015, 09:12:42 AM »
As I said, I could swivel the cover to service the filter. So this only works if you can get to the back side of the brass insert. What I did was take one of the free air box screws and put a nut on it. Then, i screwed it into the backside of the insert until it touched the stuck screw. I backed it out half a turn then tightened the nut against the insert. using two wrenches, one on each of the screw heads, I turned the stuck screw right out! used the wrenches to remove the back screw and jam-nut. I pu a little lube on the screws before I reinstalled them to prevent sticking in the future.
Andrew
1975 CB750K5
1985 GS 450E
1981 CB650 Custom
Offline cb650
« Reply #4 on: June 22, 2015, 01:25:57 PM »
Cool thanks for sharing.
