Author Topic: Trying to do the cb750 tuneup. Are there any clear and easy step by step guides?  (Read 7271 times)
and subscribe to this forum members channel....if you're a visual learner  ;D
Offline ChopSticks
Thanks I've actually watched a few videos already but it looks like most of it has been engine stuff. In regards to the clutch, since it appears he's created 2 custom tools just to get to the clutch corks, doesn't look extremely likely for myself unless that's the the main cause of my clutch problems.
the modified socket to get the 'special nut' off can be made or purchased.  it works very well.
you can also use a punch and a hammer to spin the nut loose.
one option is certainly better than the other  ;D
Offline ChopSticks
Yeah but before I dive into that, are there any other simply checks I can do first such as the clutch adjustment?
I'm also trying to compile a list of all the goods I'm gonna need, I'll add clutch remover bolt thingy on it I guess
So far I have
Timing light
http://www.amazon.com/INNOVA-3551-Inductive-Timing-Light/dp/B000EVYH72/ref=sr_1_1?ie=UTF8&qid=1434488994&sr=8-1&keywords=timing+light
Feeler gauges
http://www.amazon.com/25025-26-Blade-Master-Feeler-Gauge/dp/B000BYGIR4/ref=sr_1_1?ie=UTF8&qid=1434489004&sr=8-1&keywords=feeler+gauge
Carb sync
http://www.amazon.com/Emgo-Carburetor-Synchronizer-84-68594/dp/B003CJGDE8/ref=sr_1_3?ie=UTF8&qid=1434489026&sr=8-3&keywords=carb+sync
30.8mm o-rings for valve tappets
I would suggest getting yourself the Clymer manual.  Although several very specific specs are incorrect or missing, there are many instances when I found the directions easier to understand than the FSM, especially when I was new to wrenching.
To adjust your clutch...remove the chrome cover to the clutch, back off the adjusters at the clutch lever and the clutch housing, loosen the locknut on the clutch actuator at the engine end of the cable, turn the adjuster screw in until firm resistance is felt(don't get confused by a stuck or corroded screw, get it to turn relatively freely in and out, then go in until resistance is felt), back off the adjuster one quarter turn from the point of resistance, hold the adjuster in this position while you tighten the locknut, retention the cable starting with the adjuster on the engine, finer adjustments can be made now at any time at the handlebar clutch lever.
As mentioned earlier, your clutch plates are probably stuck from sitting around.  They will usually unstick if you can get the bike moving in gear so that fresh oil can get to them.  Start the bike in neutral, get it rolling about 5mph, give it a little gas, pull in the clutch, then firmly shift it down into first...... or try from a standstill, in neutral raise the engine speed to about 2000-2500 rpm, pull in the clutch, and try to firmly shift into first.  It may take several trys.
Offline ChopSticks
cam chain:
Any idea why he turns the engine 15 degrees? I can't see any reference for that in the manual
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
--Evan
1975 CB750K "Rhonda"
